- Thank you received: 225
Carb Jetting "Jet Chart for Mikunis"
- Old Man Rock
03 Aug 2009 05:30 #311110
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Carb Jetting "Jet Chart for Mikunis" was created by Old Man Rock
I came across this "Various Mikuni Jetting" where sharing with you guys who have these carbs.... Good or bad, unknown!
www.postdiluvian.org/~mason/moto/jetting.html
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Russ Jackson
- Thank you received: 1
03 Aug 2009 06:14 #311113
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Carb Jetting "Jet Chart for Mikunis"
Great chart and link. What we someone should do is make a chart that gives proper jetting for different variations. Like KZ900 with Mac 4 into 1, K&M Pods. There are so many options and carbs out there....Russ
- Old Man Rock
03 Aug 2009 06:22 #311114
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Replied by Old Man Rock on topic Carb Jetting "Jet Chart for Mikunis"
Unfortunately, this would be difficult due to all the variables... Engine / camshaft mods, intake/exhaust vacuum, which pods, which exhaust/baffles, elevations/altitudes, OEM or EI ignition configurations, petcocks installed, carbs themselves etc....
Yes it's a pain in the ass and we go through many different trial/error jet size before dialing it in... Only way to truly accomplish dial in YOUR setup for every motor is slightly different....
Would get you close to start your final jetting just the same....
Websites such as this is basically doing that...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
03 Aug 2009 06:39 - 03 Aug 2009 06:42 #311118
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Here you go, found an excellent article on Jetting in general....
NOTE: May be a little different in your exact carb setup but the definitions and what your trying to accomplish is the same pretty much for all carb jetting... Well defined!
scootrs.com/tech.cfm?tip=tunecarb
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Aug 2009 06:42 by Old Man Rock.
- Old Man Rock
03 Aug 2009 06:44 #311120
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
03 Aug 2009 09:12 #311158
by Patton
Replied by Patton on topic Carb Jetting "Jet Chart for Mikunis"
Another helpful source is the carb info provided by Z1E.
Scroll down to the charts, which also include 29 smoothbore.
Click here > Carb info at Z1E
Good Luck!
Good Luck!
