1979 kz650 stock jetting
- hammerdown 58
14 Mar 2006 12:41
Hello
Does anyone happen to know the stock carb main jetting for a 79 kz650. The only reason I ask is that my brother has one that is running cool on #2 cyl ( fouls plugs and pipe is a different color) Seems PO installed kerker headers and air filters and may or may not have rejetted. Thanks for the info.
- rstnick
Re: 1979 kz650 stock jetting
14 Mar 2006 19:32
My Haynes Manual says 100 for the main jet and 16 for the pilot, stock.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- N0NB
- Blue handles better
14 Mar 2006 19:45
If his '79 has the air screws that point up and outward to the left for 1 & 2 and to the right for 3 & 4, then the factory service manual provides the following:
Main 97.5
Jet Needle 5CL16-3
Pilot Jet 15
The jet needle clip should be in position 3 (middle slot).
These match my stock 1979 650 SR.
HTH,
- Nate >>
Main 97.5
Jet Needle 5CL16-3
Pilot Jet 15
HTH,
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- wiredgeorge
14 Mar 2006 19:53
There were probably 28 zillion versions of the VM24 assembly. Your bro's bike is fouling so bad on #2 that it isn't firing. If he has pods and aftermarket pipes, about #107.5 main jet and #17.5 pilots w/jet needle clipped to 4th position should be OK. The fouling isn't because of the jetting... more likely electrical.
