Ideal jetting on '79 KZ650C3...anyone?
- pete@PMH
'79 KZ650C,
Re-Building '78 KZ650B
- 2006hhr
- pete@PMH
'79 KZ650C,
- MentalMike
- God Bless America!
I went with 112.5 mains and 17.5 pilots on my '79 carbs i installed on my 78 SR 650. This bike is running a Vance and Hines 4:1 and K&N pods. Stock mains were like 92.5 or something way lean like that, stock pilots were 12.5's. The 78 carbs i got with the bike had the same jetting, 112.5 mains and 17.5 pilots. With the stock 79 carbs, the bike would hardly run off idle, lots of burping and hesitating. With the new jetting it is smooth as siklk all the way to redline. I can't see the mac system flowing much less than the Vance and Hines, so i wou,ld shoot for the 112.5/17.5 jetting, if you have adjustable needles, i.e. with the multiple notches to raise or lower the needles, then raise the needle by putting it one notch lower than stock, on mine it was the 4th notch, again the 79 carbs were not as adjustable, having just one needle position.
I've got the same setup as you on my 78 650 Custom which I found was running a little lean. I was just about to go up on my jet sizes. I think I'll try your recipe as well. Thanks
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
