ZX600 carbs on a KZ1000?
- madbikebreaker
01 Aug 2009 11:01 #310747
by madbikebreaker
ZX600 carbs on a KZ1000? was created by madbikebreaker
I know this may kinda far out there, but is there any reasonable method to bolt a good set of 1986 ZX600 carbs to a 1980 KZ1000? I bought this ninja so I can use the front end. Also how about the coils?
- otakar
01 Aug 2009 11:35 - 01 Aug 2009 11:36 #310753
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic ZX600 carbs on a KZ1000?
Those are the same junk Keihins that my brother has on his 91 Zephyr. They are cantankerous to say the least. They have the same spacing as the KZ550. You are looking at a lot of tinkering. However, if you want to mount them on your bike, it is actually quite easy. All you have to do is get a set of mounting boots for the 91 Zephyr (ZR750) and they will bring the spacing to the dimensions you want. You may just try and use the boots from your Ninja. They might be the same as the Zephyr boots.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Aug 2009 11:36 by otakar.
- Duck
- e vica na i sau na ga
01 Aug 2009 14:33 - 01 Aug 2009 14:35 #310785
by Duck
Replied by Duck on topic ZX600 carbs on a KZ1000?
Please post results. I've got a couple of sets of these/those carbs kicking around and would like to hear.
ZX600's stayed on the road for many years so the carbs can't be too bad.
IIRC ZX600 has electronic ignition so coils should work but I'd check the primary resistance first.
Last edit: 01 Aug 2009 14:35 by Duck. Reason: wanted to add notification but it must be elsewhere on the board
- fordtruck
- Thank you received: 6
01 Aug 2009 14:49 #310788
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Replied by fordtruck on topic ZX600 carbs on a KZ1000?
I had a 1985 Ninja 600 for several years and never had any trouble with the carbs. I rejetted them after drilling the airbox and installing a K&N filter, and it really woke the bike up. They were pretty lean from the factory.
- madbikebreaker
01 Aug 2009 15:36 #310792
by madbikebreaker
Replied by madbikebreaker on topic ZX600 carbs on a KZ1000?
The coils on the KZ are 2.2ohm and the ninja coils are coming up as 3.4ohm. If I keep the resistor will I burn up the CDI?
- otakar
01 Aug 2009 18:37 #310831
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
With or without the resistor, your spark would be very week with the 3.4 ohm coils. your output voltage would be only 66% as strong as with your stock coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Duck
02 Aug 2009 15:26 - 02 Aug 2009 15:32 #310947
by Duck
What resistor? Is it in series with the coils? I only have an 81/82 manual here at the house. You are not gonna hurt CDI with higher resistance coils. However...Older CDI may be inefficient owing to aging of the capacitor and a reduction in energy storage capacity. If this is the case, even perfect OEM coils transported from the past by time machine will not improve things. Do you have the ZX ignition electronics?
Are you sure you have CDI?
-Duck
-Duck
Last edit: 02 Aug 2009 15:32 by Duck.
