#3 Bowl vent - leaks on/off & removed VM26ss
- Summerheat
- Wanted at 17 Got it at 47 Worth The Wait!
31 Jul 2009 06:18 #310514
by Summerheat
1976 KZ900-A4
#3 Bowl vent - leaks on/off & removed VM26ss was created by Summerheat
Help, at a bit of a loss.....
Took carbs off to rebuild & bench sync. This #3 carb has off and on left it's mark on garage floor. Just thought stuck float valve.
In clear tube float level jig she leaked. Rebuild all 4, actually surprised at how clean all was but cleaned/cleared passages/blew air/replaced float valve's and redid clear tube check(perfect levels 2nd time ) but #3 vent still leaked.
Took bowl off and filled 1/3 full no leak, filled 1/2 full no leak, filled 1/8 below top and slow lil gas bubble forms at bottom of vent.
Air pressure in top of vent with bottom plugged... NO Air leaks.
WHAT THE HECK IS CAUSING THIS ????
1976 KZ900-A4
- Thank you received: 2098
31 Jul 2009 08:06 #310539
by Patton
Replied by Patton on topic #3 Bowl vent - leaks on/off & removed VM26ss
If not already done, would inspect for possible crack in the overflow tube.
Good Luck!
Good Luck!
