carbs too big?
- Headly
I have a z1b,1045 wiseco pistons,ported head,dyna s coils and ignition,four in one headers with titanium yoshi can.
I am currently running 33mm keihen crs carbs with foam uni filter type air cleaners. I have re jetted a few times and dropped the needles to where i feel its running fairly well.
Do you think 33mm bore is too big ,would i be better off with say 29 or something as i have a set of 76 z1000 carbs at home,just curious on other opinions as most guys around here are running big flatslides(36-38), i think this is overkill myself on smallbore bikes(900).
Thanks Jason.
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
- Old Man Rock
- Thank you received: 225
No mention of performance camshafts so assuming OEM...
Bike running sweet, seems so...
No fouling plugs, accelaration/decelaration issues when twisting or releasing the throttle, no carb or exhaust backfires, mpg/kpg reasonable ~ 30 etc...
Then leave her alone for you will feel a difference in the Keihin CR specials to those 30 year old carbs... Speaking of technology not size... Also, your head was most likely ported for those carb intakes so with that lone, leave her alone for optimium air flows into the head.
I have a 1015 cc kit with .365 mild performance cams and the 29mm CRS... When resarching my carbs, the recomendations where to stick with 29-31mm... At 33mm, and considering the work that was accomplished in your motor don't screw with it, leave her alone...
Now, picture of that exhaust pipe? :woohoo: :laugh:
Seriously, sweet Z!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 797
and welcome,beautiful bike more pictures.
leon holmes
- PLUMMEN
- Thank you received: 104
- keith1
First off, that is one beautiful KZ you have there...
Seriously, sweet Z!
OMR
i ll second that...that is one SWEET bike.....
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Old Man Rock
I'd just stick with what he has...
Just my two worthless cents worth... :blush: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Headly
