WORKING CHEAP MUTI CARB SYNC TOOL
- Motor Head
Re: WORKING CHEAP MUTI CARB SYNC TOOL
26 Jul 2009 17:14
:huh: I believe on the KAW's #2 is supposed to be treated as the MASTER carb. It is the one that the Idle speed adjustment screw is on, the others are linkage adjustments to this carb. Always make sure your basics are good before messing around trying to sync. Inspect/ clean your carb's, check for vacuum leaks- way to common on old bikes/ good even compression-needed for vacuum signal/ good ignition system-points and condenser on the oldies.
Then you won't be back in there again and again.
- DoubleDub
26 Jul 2009 18:52
Pretty sure that varies from bike to bike. The VM26 carbs I have that came on the Kz900 and Kz1000's have individual adjustments for everything but the cable linkage (slide height and pilot circuit air screw).
- Motor Head
26 Jul 2009 18:58 - 26 Jul 2009 19:14
Check where the Idle adjustment screw is for the butterflies,
I think you'll find it on #2. But really the main thing is to make sure there are no underlying problems, then adjust to the same vacuum signal in each carb. You will spend less time doing it if you start with the carb that has the Idle speed screw #2.
Now if you have the round slide VM carb's that use the slide as the throttle valve with individual speed screw adjustments for the height of the slides, then you will find he is right no real master carb. Many machines have different linkages or cables hooking multiple carb's together.
Last edit: 26 Jul 2009 19:14 by Motor Head.
- DoubleDub
26 Jul 2009 19:06
Butterfly valves are only on the CV type carbs. Many bikes have slide types which don't have a master adjustment on carb #2.
- Kawickrice
26 Jul 2009 19:33
Ok its time for the chemistry and science gurus to figure out the four bottle system. Maybe if the two inner bottles had three holes drilled they could all be linked together. Does it sound feasable?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- DoubleDub
26 Jul 2009 19:42
I found this one online - the only thing I think we'd need to figure out would be the valve to prevent the fluid from being sucked into the carb manifolds.
www.vfrdiscussion.com/forum/lofiversion/index.php/t16200.html
- toadson
06 Aug 2009 20:14
DoubleDub wrote:
Good find! I'm going to try and make one of these soon. If I get it working, I'll post my results.
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread:
kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
