- Thank you received: 28
BS34 Slide Choke Won't Stay Closed!
- TeK9iNe
- What did you do!?!
It leads to a temporary flooding/hesiation situation that is very annoying...
Any suggestions?
Maybe I should drill a little hole thru the other end and put a clip-pin in there... LOL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- KawiConvert
- Thank you received: 4
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- TeK9iNe
Are the spring and ball catches still in place? Very small, and very important. If not, you could add a spring to keep the lever in and only hold it out by hand to start.
Havn't had a chance to check...
Adding a spring to the lever sounds right up my alley.
Thanks!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- KawiConvert
- TeK9iNe
Boy- You've had all kind of problems with these carbs, haven't you? I think it is time to do a serious total tear-down overhaul. :ohmy:
LOL, I've already done that... maybe a new set is in oder for next year.
There actually starting to run pretty good now after a few more tweaks...
i fixed the choke lever problem temporarily. The rod was slick with lube which let it squirm out under vibration. I simply blasted the whole thing with brake cleaner, now it stays in place fine.
:laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
- Thank you received: 225
Easy to work on regarding jets... Even a retard like me can do it.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
