VM26SS on a KZ650, what does it take?
- jayboogz
23 Jul 2009 04:21 #308793
by jayboogz
VM26SS on a KZ650, what does it take? was created by jayboogz
If I were to purchase a VM26ss for my 78'kz650 what intake boots (between carb and engine)would I need to get? For anyone who has done this upgrade, I am interested in knowing if it was worth the effort. My goal for my bike is to give it some little added power by in a way that I can perform myself, pretty much anything short of a engine build. I am also searching the forum on a reccomended jet kit for pods and a pipe for this very set up so far no luck, I have found enough info that says it will work but, not what it will take to make it happen. Thanks for any help, meanwhile I will continue my search.
- anarki650
- Thank you received: 5
23 Jul 2009 11:51 #308842
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic VM26SS on a KZ650, what does it take?
I'm running that same set up on my 77 kz650, piece of cake to do the conversion. You'll need the carb holders from either a kz900 or kz1000 (same part, should be able to get them from Jeff at z1). You'll have to slot the mounting holes on the carb holders and sand off the little lip (designed to seat inside the intake ports on the bigger head, won't seat into the 650 head). I used a little bit of high temp silicone when mounting mine just to avoid any potential leaks with the modified carb holders. Throttle cables will be a direct swap, no worries there.
As far as jetting, with K&N pods (also purchased for a kz900 because they need to be bigger than those for vm24's) and a lightly baffled 4-1 I was running 17.5 pilots, needles on the #4 clip, and 117.5 mains. After switching to a custom fabbed 4-2 system I had to increase my main jet by one step and am now running 17.5 pilots, #4 clips, and 120 mains. K&N pods, in my experience, will require a bit larger main jet than the cheap ones, so if you use Emgo or Uni pods I'd take my jetting figures and back them off by one step.
Doing the carb swap is HUGE performance boost. I've not had my bike on a dyno, so I can't tell you specifically what kind of gain you'll likely achieve, but from the saddle it sure feels like a fairly significant gain.
Hope that helps!
Hope that helps!
09 Kawasaki ER6n
Omaha NE
The following user(s) said Thank You: KawiConvert
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
23 Jul 2009 23:41 - 23 Jul 2009 23:43 #308997
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic VM26SS on a KZ650, what does it take?
I have done this swap also. I forst had 28mm carbs off of a z1, way to much carb for that bike. I just put on the 26mm carbs off of a kz 1000, i havent ridden it yet but i can tell it has better throttle response and seems to idle better. I had the stock pipes on there but it backired and popped to no end, so i put back on my 4 into 1 vance and hines header, custom bent mid-pipe, and a yoshimura slip on exhaust can off of a gsxr 600, the popping and back firing is gone now, it sonds really cool with the yoshi on there. The 26mm carbs slipped into my stock intake manifolds, but they are new and soft so im sure that is why.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 23 Jul 2009 23:43 by oldkaws4ever.
- jayboogz
24 Jul 2009 07:41 #309031
by jayboogz
Replied by jayboogz on topic VM26SS on a KZ650, what does it take?
Good looking out Anarki that is exactly the info I was looking for. I will have to order those parts and develop a better understanding of the process to mod the carb holder. By the way is that your KZ in your avatar? That ish is sweeeeet!
- jayboogz
24 Jul 2009 08:37 - 24 Jul 2009 08:40 #309037
by jayboogz
Oops, double posted.
Last edit: 24 Jul 2009 08:40 by jayboogz.
- anarki650
24 Jul 2009 19:48 #309146
by anarki650
09 Kawasaki ER6n
Omaha NE
jayboogz wrote:
Glad to help!! And yeah, that's my baby in my avatar, thanks for the compliment!!!
You'll see when you get the carb holders what I meant by stretching the bolt holes and sanding off the lip. I used a dremel with a skinny stone to stretch the bolt holes, a hell of a lot easier than using a hand file!!! The lip on the backside isn't very big and a quick hit with some sandpaper will let you level it off without screwing up the mating surface, just go slow and easy on modding them so you don't end up having to buy more!!
09 Kawasaki ER6n
Omaha NE
- spudbudy
- Kick it like you mean it
27 Jul 2009 13:18 #309649
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Replied by spudbudy on topic VM26SS on a KZ650, what does it take?
Just chiming in on this one I'm currently working at put some VM26's on my 650. I got them off a Suzuki GS750 and the cables don't work one will the other won't. I just got done checking the stock airbox will work if thats the way you want to go. the boots from a 900 fit into the stock 650 airbox just fine. Of course you must change the jets I'km going to start with 15 pilot and 105 mains. Have both air and pilot screws. A work in progress. Good luck
