Carb question
- fandango
Any suggestion?
- Thank you received: 2098
Guessing maybe a 24 being fitted instead of a 28.
Thinking that jetting won't compensate for smaller bore (carb throat) size, especially at higher rpm.
Good Luck!
- fandango
- Old Man Rock
- Thank you received: 225
In reference to your writing of "I swap on a KZ650 carb"...
This is singular and am assuming you meant the set of 4 but have to aske just the same... Am I understanding you swapped the SET (4) of carbs not just an individual carb.. Correct? :S
In either case, as Patton mentioned, would it start, maybe, would it run like crap, most likely due to jetting and head intake bores...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- fandango
- Old Man Rock
"My first thought was too small main jets." ...
@ 8000 rpm, Yup WOT, most probably main jets in this case.
Same time, this may be the point where the needle jet and main jet curves overlap.
Does it "die" then kick back in or just falls on it's face at that point?
You may want to try changing your needle jet clip position for a more richer operation if it isn't falling on it's face for the WOT range.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- fandango
- fandango
Here is little update.I cleaned up the kz1000 carbs and put it back.It runs awesome but there is one thing still bugging me.It has a "floating" idle effect.When I revv it up it stays there for a bit and going back slowly.I think it`s either sync problem or airscrews out of specs.Any thought on this one?What should I check.And this is a smoothbore which I`m not familiar with.I worked on honda cb`s but this thing is different.
Thanks
- Old Man Rock
Reviewing static adjustments, when the throttle is opened and released, do the slides "Snap" spring back to start positions/heights in the bodies?
Possible vacuum leak but your gauges should provide some insight to that....
Those images depict some pretty nasty grunge and possible now that you have them running, some of that black crap residue is working it's way through the carbs.
You went from crap running, cleaned to awesome not with a little hang up... Good job!
Me personally speaking, before doing any other adjustments... take them off and clean again!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Hi!
Thanks
I think it`s either sync problem or airscrews out of specs --- possibilities, or perhaps hanging throttle cable for whatever reason or a weak return spring.
But imo the culprit is more likely an air leak in the carb holder (old and cracked) or loose clamp at carb holder, or leak where carb holder attaches to engine.
Typical test is by spraying WD40, carb or brake cleaner, or propane gas (unlit--duh :lol:) around the carb holder area while engine is idling.
A noticeable difference in idle rpm usually indicates the unwanted intrusion of outside air into the fuel mix as it enters the intake tract on its way to the combustion chamber.
Good Luck!
- fandango
OMR!
I took off and back three times already,that is my magic number.I always find a little hole somewhere.The final procedure was boiling the jets and the whole carb.
- Old Man Rock
Even with new manifolds, I put a little vacuum grease on the outside sleeves to insure no leaks....
When this hang up occurs, with gauges in place, are all 4 carbs acting up or just one?
As Patton mentioned, weak spring, cable hanging up...
Open the throttle, while reviewing the cable tensioner/springs, release the the throttle and let it snap back to idle... Are you seeing the hang up in the mechanical spring adjuster plate area or is it truly in the carbs themselves...
I don't know your carbs so just guessing but if all 4 are acting up simultaneously then has to be something in common they all work off of such as choke assemblies, starter circuits etc...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
