- Thank you received: 35
Interesting holes in float
- moneypit
20 Jul 2009 20:41 - 20 Jul 2009 20:43 #308349
by moneypit
2-76 kz900
St Paul MN
Interesting holes in float was created by moneypit
I noticed while setting float height on 29mm smoothies and one float has about 6 holes in it. I figured I coukd solder it. Will this affect it in any way.
2-76 kz900
St Paul MN
Last edit: 20 Jul 2009 20:43 by moneypit.
- moneypit
20 Jul 2009 20:44 #308351
by moneypit
- moneypit
20 Jul 2009 20:46 - 20 Jul 2009 20:48 #308352
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Interesting holes in float
soldered I cant finger out how to load 2 pics
THANK GOD FOR THE EDIT BUTTON BUT THE DAMN PIC WONT LOAD
2-76 kz900
St Paul MN
Last edit: 20 Jul 2009 20:48 by moneypit. Reason: Cant load pic w/edit
- moneypit
20 Jul 2009 20:49 - 20 Jul 2009 20:49 #308353
by moneypit
Last edit: 20 Jul 2009 20:49 by moneypit.
- moneypit
20 Jul 2009 20:52 #308354
by moneypit
- JR
- Thank you received: 449
21 Jul 2009 12:59 #308447
by JR
Replied by JR on topic Interesting holes in float
Looks like avery nice soldering job.
I dont know anything about carbs for the 900 but if it were in my 750 I would just set it so the fuel level in the float bowl was about 4 or 5 mm below the top of the bowl. i.e where it was supposed to be.
- Thank you received: 2098
21 Jul 2009 14:14 - 21 Jul 2009 14:22 #308457
by Patton
Replied by Patton on topic Interesting holes in float
JR wrote:
Service floatbowl fuel levels below edge of carb body per FSM for oem carbs on the large fours are:
'73Z1~'76KZ900 @ 2.5 +/- 4.5 mm (.10~.18 inch, about 1/8")
'77KZ1000~'78KZ1000 @ 3 +/- 1 mm (2~4 mm)
'79 KZ1000 @ 4 +/- 1 mm (3~5 mm)
Sudco (Mikuni) 4th edition's info about 29 smoothbore doesn't show the float level specs (at least not that I can find) . Seems like Sudco should have provided such info in its otherwise excellent manual. Nor is it shown in Z1E's carb i.d. section.
Lacking better information, I arbitrarily settled on 2~4 mm, which has proved very satisfactory for the Yoshi modified 1973 Z1 in combination with other existing jetting and settings.
Perhaps somewhere out there is Word from the Mountain about recommended range for service floatbowl fuel level in Mikuni 29mm smoothbores.
Same question was addressed in this earlier KZR forum thread > ?? Smooth bore float level ?? .
So the great mystery continues. :lol:
Meanwhile, I'll happily defer to JR's advice of about 4 or 5 mm below the top of the bowl (which am wild guessing might also be the factory specs for an oem 750 CV carb).
Good Luck!
Good Luck!
Last edit: 21 Jul 2009 14:22 by Patton.
- moneypit
21 Jul 2009 15:30 - 21 Jul 2009 15:31 #308466
by moneypit
2-76 kz900
St Paul MN
Thanks guys, 4-5mm is about 1/8 inch I believe.
What would you suggest for jet size, its a 900 bored to 1015 stock airbox and pipes. Still tryng to get it put togeather, meaning the motors still in my basement:laugh:
Just need to get the carbs finished up
2-76 kz900
St Paul MN
Last edit: 21 Jul 2009 15:31 by moneypit.
