looking for a few opinions
- Bicycle Lee
Secondly... I have a set of vm28's that need a good rebuilding. Who should I send it to? I know Wiredgeorge does great work, but is there anyone who is more affordable who does the same quality work?
Thanks
1978 KZ1000 police
- Thank you received: 2098
So the frame is off at the powder coater... engine is mechanically sound, but I still think I'm having carb issues. I started it up yesterday and it wouldn't run without the choke and had some hesitation on throttle.... sounds like a carb thing to me... any other opinions? I thought MAYBE it could be ignition timing, but not sure. Any time it won't idle properly, it's a carb issue... right?
Thanks
Would first rule out compression or ignition issues before addressing carbs.
Compression test;
Assure valve clearances to specs;
Verify ignition timing with strobe light;
Visually observe spark quality with plugs removed;
Assure ample clean fuel supply to carbs, as fuel starvation may result from several different reasons including such things as clogged tank cap vent, petcock screen, inline fuel filter, etc.
Check fuel level using the clear tube test.
If problem persists after above, it's likely a problem in the carb pilot circuits.
Good Luck!
- Bicycle Lee
1978 KZ1000 police
- Bicycle Lee
1978 KZ1000 police
