Carb issues again
- KOOL RYDER
- KZ 650B2 / KZ 1000E
21 Jul 2009 10:27 #308418
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic Carb issues again
Check the vaccume line from the petcock to the carbs for cracks and make sure it is seated properly on the nipple.
Are you sure that the vaccume line is connected to the right port and not the vent nipple.
1978 KZ650B
1979 KZ1000ST
- otakar
21 Jul 2009 11:13 #308424
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Carb issues again
KOOL RYDER wrote:
A 76 900 has no vacuum petcock. It is a simple three position ON, OFF, Reserve.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Born Dead 2
23 Jul 2009 06:10 #308810
by Born Dead 2
Replied by Born Dead 2 on topic Carb issues again
Ok, so here is the latest. So I benched synced the carbs again to spec's and was going to install them. First I thought i better check the jets sizes again to be sure.
So This is where I need some "expert" advise. So before all the problems started as previously mentioned above, I had old pods that were toast and headers and slipons with a 2" pipe from the collector to the slipon about a foot long between. So with the old pods everything ran fine, lot's of power no bogging or flat spots ran as it should. So I checked the jetting last night which was with the old pods and it has 17.5 pilots and 115 mains. So with the new filters and sync nothing, bike ran like shit. So I've gotten 122.5 mains to replace the 115. I thought they were 118's but I guess with age I don't see as well.....So my question is, with the bigger mains will I have to move the clip on the needle also or will putting bigger mains in and sync be enough?
I'm still trying to figure the whole carb thing out so bear with me..
Thanks again for all the input so far.
BD
BD
- TeK9iNe
- What did you do!?!
- Thank you received: 28
23 Jul 2009 11:59 #308844
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Carb issues again
Hope this helps...
Jetting/fuel delivery, is governed primarily by the throttle position.
Having larger Mains really only helps the last 3rd or so of the throttle range. I can say from experience that max speed/hp and high revs are what are benefit by the Main.
Good Luck.
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Born Dead 2
24 Jul 2009 06:33 - 27 Jul 2009 10:42 #309011
by Born Dead 2
Hey thanks man, it'll help alot.
Thanks again.
BD
Thanks again.
BD
Last edit: 27 Jul 2009 10:42 by Born Dead 2.
- Thank you received: 2098
24 Jul 2009 06:59 #309019
by Patton
Replied by Patton on topic Carb issues again
Lowering the needle clip position will raise the jet needle higher inside the throttle slide, whereby a smaller section of the taper interacts with the needle jet, which allows more fuel at mouth of the jet, and results in richer mid-range carb performance.
Good Luck!
Good Luck!
- Born Dead 2
24 Jul 2009 11:06 - 24 Jul 2009 11:06 #309061
by Born Dead 2
Thanks Patton. I hope to get this thing figured out soon. Damn pods....Oh have I mentioned how much I hate carbs...LOL
Last edit: 24 Jul 2009 11:06 by Born Dead 2.
