Fuel T inlet replacment
- Yojymbo!
12 Jul 2009 18:49 #306572
by Yojymbo!
Fuel T inlet replacment was created by Yojymbo!
Has anyone replaced their fuel inlet T fitting on Mikuni carbs? Mine is toast and the gaskets are part of the fitting. I'm considering going to the hose/hydrolic shop and getting 2 90degree fittings up on and running L & R inlets to the carb banks as the part is no longer available. Is there any reason not to do this?
- Sandy
- Fly High,Tony
- Thank you received: 13
12 Jul 2009 21:52 #306661
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Fuel T inlet replacment
If they are leaking,you can use teflon-tape to reseal them.
1977 KZ1000 A-1
- Thank you received: 797
13 Jul 2009 08:27 #306695
by 531blackbanshee
Replied by 531blackbanshee on topic Fuel T inlet replacment
- Yojymbo!
13 Jul 2009 13:02 #306742
by Yojymbo!
Replied by Yojymbo! on topic Fuel T inlet replacment
Yes, but they are 24mm carbs. Gasoline won't eat teflon tape?
- mtkawboy
- Thank you received: 16
13 Jul 2009 15:19 #306777
by mtkawboy
Replied by mtkawboy on topic Fuel T inlet replacment
It hasnt on my Z1 I did a few months ago
- fixer5000
- Thank you received: 5
13 Jul 2009 15:41 #306784
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Fuel T inlet replacment
i think id try adding an o ring between the bumps there
massachusetts
- azman857
- Thank you received: 112
14 Jul 2009 01:23 #306900
by azman857
Replied by azman857 on topic Fuel T inlet replacment
This might help at Mike's XS.com they sell "T"s and the flat gaskets for the XS 650. Go to "Fuel System- Gas Tanks,Gas Caps,Petcocks,Parts. Scroll down...and down..almost to the end.
Its for the BS 34 carbs. PN# 48-0885 for the gaskets 2/ $1,48-0884 for the brass "T" and 2 gaskets. Worth checking out
