1980 kz1000 duel petcock problem
- terry s
08 Jul 2009 18:00 #305515
by terry s
1980 kz1000 duel petcock problem was created by terry s
I have a dual port petcock non vacume. The rear fuel tube pulled out of the body. Is there a fix to this? It does fit snug when I push it back in. Has anybody used any sealer and pushed it back in and what did you use?
- MFolks
- Thank you received: 540
08 Jul 2009 19:16 #305535
by MFolks
Replied by MFolks on topic 1980 kz1000 duel petcock problem
Use acetone and a cotton Q tip to clean both parts. Then get some Loctite # 262 and apply a drop or two quickly assembling the part. To insure a tight fit, get a block of wood and tap the part with it with a hammer. Let it set up and the fix will be good.
- RonKZ650
- Thank you received: 240
08 Jul 2009 20:44 #305545
by RonKZ650
Replied by RonKZ650 on topic 1980 kz1000 duel petcock problem
JB weld epoxy works great for this too. Not effected by gas after it hardens.
- sbulla
- 1980 KZ1000 LTD
09 Jul 2009 14:13 #305688
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Replied by sbulla on topic 1980 kz1000 duel petcock problem
X2 on the JB Weld. That's what I used on mine.
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Iron Duke
- what are you rebelling against?
09 Jul 2009 22:47 #305819
by Iron Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
Replied by Iron Duke on topic 1980 kz1000 duel petcock problem
Seal All or J B weld should work.
1982 KZ550 LTD C-3
