- Thank you received: 1
82 KZ550 A2 carb tuning...help?
- 550A2
- keep the shiny side up
08 Jul 2009 15:35 #305496
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
82 KZ550 A2 carb tuning...help? was created by 550A2
I had the carbs syncronised, it did give it more power, but it still idles rough, and i cant seem to make the right carb adjustment to fix it.
Ive read through the owners manual, and it says turn all the screws in all the way then out 2 1/2 turns. thats what i did. nothing changed.
Any suggestions?
Any suggestions?
- GPz550D1
- Thank you received: 22
08 Jul 2009 17:44 - 08 Jul 2009 17:46 #305512
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic 82 KZ550 A2 carb tuning...help?
I have my TK22 carburetors pilot screws set at 1 3/8 turns. If you have TK22's, 2 1/2 turns is likely too much. Between 1 1/4-1 1/2 should be just about right. Look and listen for any possible vacuum leaks.
Robert
Robert
1981 KZ550-D1
Last edit: 08 Jul 2009 17:46 by GPz550D1.
- loudhvx
- Thank you received: 1616
09 Jul 2009 05:27 #305603
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 82 KZ550 A2 carb tuning...help?
Yeah, I'm not sure which manual you are using, but 2-1/2 turns out is too much on the air screws. Like GPz550D1 says, it should be about 1-1/4 to 1-1/2. The factory manual says 1-3/8 +/- 1/4.
From the photo (very nice looking bike, by the way) it looks like your bike is stock. If the mixture screws don't fix it, there are many things that can cause a rough idle.
If the bike is new to you, start with a compression test and you may want to check the valve lifter clearance. From there, check the timing and ignition. Verify the advance is working with a timing light. The light will also show if you are getting misfires.
Then start on carbs.
1981 KZ550 D1 gpz.
Other links.
- 550A2
09 Jul 2009 06:44 #305618
by 550A2
Replied by 550A2 on topic 82 KZ550 A2 carb tuning...help?
Its pretty much stock, i got a 4-1 header, a ngk coil pack and i removed the pcv valve system.
I replaced all the top end gaskets a week ago, i measured the valve clearance and its within spec.
ive checked the ignition timing too and its spot on.
thats what i thought the problem was.
ill mess around with the screws, see if i cant dial it in.
Thanks.
luke
Thanks.
luke
