a little help
- OregonMatt
07 Jul 2009 19:35 #305208
by OregonMatt
1976 kz 900
a little help was created by OregonMatt
I was pulling my carbs apart to re jet and adjust the needle level. When i went to adjust the needle in carb 3 when i discovered that the arm that attaches to brass thing that the needle sits in is broken. Is this fixable, or am I going to need new carbs
1976 kz 900
- OregonMatt
07 Jul 2009 19:36 #305210
by OregonMatt
- TeK9iNe
- What did you do!?!
- Thank you received: 28
08 Jul 2009 18:55 #305526
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic a little help
Replacement carb stuff can be found here and there...
www.cyclepartsnation.com/pages/parts/viewbybrand/default.aspx
Or you could just have a local shop fab a replica of one of the other pieces.
Good Luck.
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Online
- Thank you received: 2237
08 Jul 2009 19:15 #305532
by TexasKZ
Replied by TexasKZ on topic a little help
You might also check with wiredgeorge or even Jeff at Z1E. Somebody is bound to have one or two gatherin' dust in a dark corner someplace.
