83 kz750 L3
- krazinite2003
06 Jul 2009 18:08 - 06 Jul 2009 18:10 #304885
by krazinite2003
i have two 1983 kz750 L3
83 kz750 L3 was created by krazinite2003
hey guys newbie to bikes here
ok heres the deal i have had an 83 kz750 L3 given to me in boxs in pieces yup striped right down to the frame well i have it mostly together to the piont whare it turns over by its own power and no book to look at. ok now what i cant figure out is where do all the hoses go to from the carbs i have 5 of them i know the biger one between carbs 2 an 3 goes to the pet cock but thats it lol now on carb 2 thares a smaller hose does that one go to the petcock as well? and the hose on carb 3 goes to atmosphere right now there is two clear hoses that are attached to tee's one between carbs 1 an 2 and one between carbs 3 an 4 i am thinking thes are vent hoses now i have read some where that thes would go to a little plastic holder attached to the frame just under the back of the fuel tank oh and i should mention the bike is from canada where i live and i have found a jet of some sort in the hose between carbs 3 an 4 canadian models only i think is what a book said. is all this right any help would be great thanx in adavance
Last edit: 06 Jul 2009 18:10 by krazinite2003. Reason: incomplete
- telefunkin
07 Jul 2009 05:03 - 07 Jul 2009 05:05 #304984
by telefunkin
Replied by telefunkin on topic 83 kz750 L3
Are those the Keihin CV34'S? If so then yes the tee lines between 1-2 and 3-4 are vent lines. I beleive the vacuum line on carb 2 will go to the petcock and vacuum line on carb 3 may go to the airbox. Sometimes vaccuum lines on 1 and 4 are connected to a tee line and then to the airbox but I think the canadian models are just the one line from carb 3 into the airbox usually.
See this link for more info.
www.wgcarbs.com/index.php?option=com_con...view&id=25&Itemid=25
Last edit: 07 Jul 2009 05:05 by telefunkin.
- krazinite2003
07 Jul 2009 05:51 - 07 Jul 2009 05:52 #304988
by krazinite2003
Replied by krazinite2003 on topic 83 kz750 L3
sorry these are mikunies i will try uploading a couple pics
Last edit: 07 Jul 2009 05:52 by krazinite2003.
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
07 Jul 2009 08:58 #305028
by Grantl
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Replied by Grantl on topic 83 kz750 L3
The correct carbs for that bike are Mikuni BS34's. You are right, the hoses coming from the tee's between carbs 1 and 2 and 3 and 4 are overflow vents. The hoses attached to the tee's should be routed down towards your swingarm but not right at your rear wheel. On the vacuum side, 2 of the vacuum hoses-ports on the top-front of the carbs should go to the fresh air valve system and 1 goes to the vacuum operated petcock. One of the vacuum ports just gets a plug. I have the same bike so if you need pics of where things go, just let me know. I'm in the process of switching out my motor, so I should also be able to provide some assembly pics if you need.
Best of luck,
Grant.
Best of luck,
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- krazinite2003
07 Jul 2009 19:46 #305218
by krazinite2003
well this is frustrating lol yes any pics would be great
ok the two vent hoses that you say go by the swing arm can they go any where cause i have a plasice piece that is bolted to the frame just above the carbs and i have found a refrance pic that looks like what i have could this be where thes hoses go
carburettor vent hose routing -z750p model is what the haynes book is saying
now the other hose that comes from carb 3 on the front of the car vacuum i think now i read somewhere the canadain model has a jet of some sort where does this go
- krazinite2003
07 Jul 2009 19:51 #305224
by krazinite2003
dam wrong pic but any way that is a pic of the plastic piece i am talking about the next pic is the carbs with hoses atatched
- Grantl
07 Jul 2009 20:48 #305253
by Grantl
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
The pic of the little box setup right above the airbox was probably used as a gasoline fume collector at one time. My bike has the same device but nothing is connected or routed to it.
I've not heard of any kind of Jet that is on the exterior of these type carbs.
The hose coming from the top front of #3 carb will go to your vacuum petcock (if you have one). Its hard to see by the pic, but it looks like the vacuum hose from carb #1 is also connected to carb #2. They should not be connected to each other. This is unnecessary.
If you have the fresh air return valve setup (Most california bikes did,) (2) of your vacuum lines should connect to that valve, if not, just plug the connectors with the same type plug as on carb #4.
Hope this helps.
grant.
Hope this helps.
grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- krazinite2003
09 Jul 2009 04:55 #305591
by krazinite2003
ok i have found the pic of that hose that is comming from carb 3 vac fitting the one with the jet in the hose canadain models i wil try and up load it. in the pic it is part number 92063 they call it main jet if this pic dont work it is at kawasawi parts warehouse this is the only hose i can not figure out where the dam thing goes and why it has a jet in it
- Grantl
09 Jul 2009 08:36 #305635
by Grantl
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
That "jet" looks like a vacuum limiter... Basically what it does is soften the swings in vacuum pressure coming from the carbs... It evens it out.
Do you have the hose with the jet in it still?
Do you still have the vacuum operated petcock? If so, that is where the line with the jet goes.
If you don't have the fresh air inlet valve setup going to the cam cover, you only need the one vac line to the petcock. If you don't have a vacuum petcock, you don't need any vac lines, just plug them all.
Grant.
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
- krazinite2003
09 Jul 2009 17:58 #305754
by krazinite2003
yes i do still have the hose with the jet in it
yes i do have the vac operanted pet cock
no i dont have the fresh air set up
ok now my question is can i moove the hose from carb 3 which has the jet in it over to carb 2 and plug the vac fitting on carb 3
i am really sorry for being such a pain in the butt as i said im new to bikes , it just doesnt make sence the this would have the hoses it does if i dont need them . in my eyes if the bike has 5 hoses they have a use lol but you know more than i do and i thank you for your advice and im sure ill need it again lol i will post pics of this project
- krazinite2003
05 Aug 2009 05:55 #311709
by krazinite2003
well its running not great but its running
