Adjusting float ???
  • ProStreet
  • ProStreet's Avatar Topic Author
Adjusting float ???
04 Jul 2009 22:04
#304494
I took the carbs apeart cleaned the carbs on a 77 kz1000 ltd and was ptting together when I realizes when I pushed up on the first one it would stick in the up position (these are rubber coated floats)how do I adjust the floats so they won't stick like that ? only doing on # 1 and #4 carbs
Thanks
Tom
  • Mark Wing
  • Mark Wing's Avatar
Re: Adjusting float ???
04 Jul 2009 22:45
#304499
All you can do is just bend the floats a little till they clear what ever there rubbing on,
Mark
Yorba Linda Cal.
  • ProStreet
04 Jul 2009 23:03
#304500
Thank You !!!
Tom
