1980 kz1000 ltd carb issues
- terry s
03 Jul 2009 11:21
I am going through my carbs and have a question. I took everything apart on the bottom end of the carbs and soaked and blew air in every port hole. The top slides look real good. I took the top covers of the carbs off to look in them. Everything looks real good on the top. I did not take the slides out of the carb. I left all the carbs together on the rail. The gaskets are not torn on the top covers. Can I reuse the old gaskets on the top? Is this a crucial area? I am going to put new gaskets on the bowls and new o rings on the main jet tube and drain screw. I was going to replace them but they are backordered. Should I try to locate some more gaskets?
- PLUMMEN
Re: 1980 kz1000 ltd carb issues
03 Jul 2009 11:34
you should have no problem reusing top gaskets,im a cheap bastard and also reuse bottem ones if they arent torn.i learned a trick years ago if you put chapstick on both sides of a new carb gasket it keeps them from sticking so you can reuse them if youre carefull
- terry s
03 Jul 2009 13:58
thanks for your input. All of the top gaskets did not tear. By the way I am a cheap b. also. I think I will just flop this back together then.
- otakar
03 Jul 2009 15:14
I'm with PLUMMEN, the Top gaskets just keep out the weather. The lower gaskets however I would replace because they get hard and start leaking. They only cost a buck or two each, and that is not worth having to tear everything back apart.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
