air box
- irish mike
- 79 kz 650 b3 rat rod
03 Jul 2009 06:54 #304051
by irish mike
air box was created by irish mike
hi again everybody-when i remove my airbox on my 79 kz650 what do i do with the main air line and any other vacum lines atached to it ?[removing to run pod filters]---thanks irish mike....
- boots
03 Jul 2009 06:59 #304052
by boots
present bikes 1976 KZ900, 1978 KZ650 Past bikes Too many to remember!!Mostly Kawasakis and a few Sportsters
81 cb650
Replied by boots on topic air box
I plugged mine.
81 cb650
- Thank you received: 2829
03 Jul 2009 07:06 #304055
by 650ed
Replied by 650ed on topic air box
At the very least you'll need a little filter on the breather cover so your crankcase can breathe. I wouldn't recommend plugging the crankcase. Ed
- PLUMMEN
- Thank you received: 104
03 Jul 2009 10:01 - 03 Jul 2009 12:06 #304112
by PLUMMEN
Replied by PLUMMEN on topic air box
just cap off the smog lines where they come from top of valve cover
Last edit: 03 Jul 2009 12:06 by PLUMMEN.
- Russ Jackson
03 Jul 2009 10:15 - 03 Jul 2009 12:39 #304117
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic air box
Last edit: 03 Jul 2009 12:39 by Russ Jackson.
- Bluemeanie
- Thank you received: 14
04 Jul 2009 06:33 #304323
by Bluemeanie
Replied by Bluemeanie on topic air box
Russ Jackson wrote:
Like he said!! :woohoo:
Seriously, just cap off the nipples at the carb holders, and most of us just run a (3/4" I think) heater hose from cover to cover. You can install a small K&N type filter on the crankcase breather or run a hose over your swingarm.
- boots
07 Jul 2009 12:11 #305074
by boots
81 cb650
I did put a filter on my crank case!
Boots
Boots
81 cb650
