kz 550 carbs??
- drumrooster
02 Jul 2009 19:19 #303988
by drumrooster
kz 550 carbs?? was created by drumrooster
got a kz 550 82 model with the little cone filters and stock pipes..when i got it it had bad gas in it from setting,,gas had tarnished,,so i drained the tank and rinsed it out,,put on a a filter,,took the carbs apart and cleaned all the jets and bowls,,it ran but when cold it woul not rev hardly at all till it got hot? and then it sounds like its sucking alot of air kinda foooop fooop,,after it warms it starts good? it sat for a month and now it wont start hardly at all??..so took the carbs off again and the were clean??
do i need to lower the slides for the air filters and maybe go up 1 size in jets??,,
- GPz550D1
- Thank you received: 22
03 Jul 2009 05:11 - 03 Jul 2009 12:27 #304041
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic kz 550 carbs??
Do you have the TK22 carburetors? If so, you can try running the air screws at 1 1/4 turns out from lightly seated. Turning them in will richen the idle and low speed mixture slightly. Might try raising the needle jet one notch or put a small washer under the clip if it is non-adjustable. I would be worried that the air sound that you hear might be a vacuum leak somewhere.
Robert
Robert
1981 KZ550-D1
Last edit: 03 Jul 2009 12:27 by GPz550D1.
- harm
- Tom
- Thank you received: 13
04 Jul 2009 09:02 #304347
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic kz 550 carbs??
I'm thinking the vacuum line that runs from the petcock to the carbs is off. This has happened to me and the motor will barely run.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- drumrooster
05 Jul 2009 20:04 #304640
by drumrooster
Replied by drumrooster on topic kz 550 carbs??
air line is on and its just sucking alot of air through the carbs..I dont know what carbs they are? i"ll see baout the air mixture..i"m thinking goin up 1 size on the jets?
anyone know what the stock jet size wouldbe befor i pull the carbs again? and a good place to get them?
thanks
thanks
- ClassicNoob550
12 Jul 2009 12:05 #306488
by ClassicNoob550
'82 KZ550 LTD
Replied by ClassicNoob550 on topic kz 550 carbs??
I just had my '82 KZ550 LTD in the shop for carb balancing and they were balanced, but there is a leak(s) in the carb holders. I am having some of the same issues as you. Choke on seems long, rough, slow idle at start, and slight miss going down the road, etc.. You can check for leaks in the holders (
www.z1enterprises.com/detail.aspx?ID=2680
) by spraying some wd40 or other flammable around the holders. If they are sucking in at the leaks you will hear the difference. My understanding is that these bikes shipped lean for emissions and so if you have any leaks, it will run way too lean. I know that when I replaced the old air filter with rotted foam gasket with a new tighter fitting one I got an immediate improvement. I'll have new holders and air box hoses (
www.z1enterprises.com/detail.aspx?ID=331
) soon.
'82 KZ550 LTD
