bs34 jet needle
02 Jul 2009 13:03 #303900 by toad
bs34 jet needle was created by toad
ok I have changed my kz900 over from the 26mm carbs to the bs34mm with 140 mains and 40 pilots.My timing is correct, sparkplugs, wires , coil mod and carbs were cleaned and synched. Now the bike does run pretty well but I still feel these carbs are still not quite right,in fact the 26's were almost equally as good so I'm left to believe in the jet needle which is a single clip (5GN45). My question is should I try to shim this needle for better performance?
I have great top end when I hit aroud 7000rpm but down around 3500 to 5000 its just not that great,also my air/fuel mix screws are 1 3/4 out from lightly seated.I have a kerker with pods as well. Any opinions would be great Thanks All for the tips!
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • Grantl
  • KZRider is Da Bomb!!!
02 Jul 2009 14:40 #303919 by Grantl
Replied by Grantl on topic bs34 jet needle
I've heard that people do this. Over on the Buell forum, they use # 4 washers under the head of the needle and they say it makes a big difference in the mid-range. These washers can be found at crafts and hobby stores. One washer measures approximately .050" thick.
If you shim the needle, what is the worst thing that can happen? It might run worse, but if it does, just remove the shims (washers)and you should be back to what you originally had. best of luck, and report back to let us know if it makes a difference.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
02 Jul 2009 14:50 #303921 by Buda
Replied by Buda on topic bs34 jet needle
The needle from my BS34s is a 5fl51, factory for my 82 1000. What bike did your carbs come off of.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
02 Jul 2009 15:51 #303931 by toad
Replied by toad on topic bs34 jet needle
I got them off ebay apparently rebuilt.He said they were from a kz1000 police bike but he didnt know what year, they are bs34's. The stamp on the carb is V209 H781. Does anyone have any ideas thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
02 Jul 2009 15:59 #303932 by otakar
Replied by otakar on topic bs34 jet needle
The 5GN** is much richer than the 5FL**. These carbs might be way too much for a stock 900 motor with the stock cams. The cams on a stock 900 are only about a 280 lift. The 34CV carbs are equivalent to about a 31mm smoothbore. That is a lot of carb for a low lift 900.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
02 Jul 2009 16:05 #303935 by otakar
You must realize that the 900 has the same bore as the 750, while the 750 has a much higher cam lift. You would also have to modify the slides or run an airbox to create a greater vacuum. Without proper mods to the carbs you will have a hard time making it run right with stock cams. You would have to install cams with at least 340 lift to create enough vacuum.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
03 Jul 2009 06:14 #304048 by toad
well I do plan on doing some work on it this winter but for now as far as carbs go what would be a good starting point?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
03 Jul 2009 12:31 #304157 by otakar
If you are running pods, you will have to modify the carbs regardless. You are not creating enough vacuum to move the slides properly. This is why you have a lean mid range.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
03 Jul 2009 14:20 #304184 by Old Man Rock
Replied by Old Man Rock on topic bs34 jet needle
SUDCO.... Under J for Jets.... ;)
www.sudco.com/onlinecat33.html#j
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
03 Jul 2009 15:07 - 03 Jul 2009 15:09 #304186 by otakar
SUDCO unfortunately dose not carry 3mm needles for anything smaller than a 44mm carb. These are for the big twins. This is because Mikuni dose not make them. The only way to get hi performance 3mm needles is to buy a Dynojet kit or to have them made like I do, for the modifications I do on these carbs. Kawasaki no longer sells these needles either, stock or otherwise. I personally do not care for the Dynojet needles, because I think they are much TOO rich. Plus I do not care for their jets. I prefer the Mikuni jets.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 03 Jul 2009 15:09 by otakar.
03 Jul 2009 19:09 #304246 by toad
So should I try shimming the needle I have now,You were saying it is a very rich needle and this is why I have a lean mid range,I am not sure if I am too rich or too lean please clarify your opinion as to which route I shall go.Thanks for your insight.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
03 Jul 2009 19:32 #304253 by otakar
You do not have to shim anything. This is not a needle problem this is a slide draw problem. You are not producing enough vacuum to draw up the slides properly and draw the needles up. The reason you are too lean is because the needles are not being puled out the "Needle Jet". This is a "slide" problem. As designed, these carbes are too big for that engine setup. The entire carb will have to be modified,Unless you install a very restrictive airbox.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
