Airbox mod???
- dkmk
Airbox mod???
12 Mar 2006 12:50
I was checking the downloads section, and cannot find the document regarding the stock airbox mod? Tried searching, but comes up blank. Could someone point me in the right direction, a link or perhaps e-mail? (oops, forgot that Men are not supposed to ask for directions,
) Thanks in advance.
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- rstnick
Re: Airbox mod???
12 Mar 2006 19:41
Which air box mod? I don't remember one.
Only thing I recall was drilling more holes into the air box cap's lower portion to allow more air flow. Is this the one?
While on the subject of allowing more air flow into the box; If the retangular plastic piece that sits just towards the front of the Air Box Cap were removed, would that allow more air to enter the air box?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- RetroRiceRocketRider
Re: Airbox mod???
12 Mar 2006 20:16
The only airbox mod for the 650's that comes to mind, is the one where the portion of the air filter lid that inserts inside the air filter itself is cut...leaving JUST enough to hold the filter in place.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- mariozappa
Re: Airbox mod???
13 Mar 2006 06:40
I did the air box mod R4 speaks of, but I just drilled more holes in the cone of the air filter cap.
I did not see any noticable difference anywhere.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- NebrMotoPartsInc
Re: Airbox mod???
14 Mar 2006 22:05
i have seen the things from UNI that you just drill holes in the air box and put these rubber push in things that have foam in them to help filter dirt.
is that what you are speaking of?
- kz550krazy
Re: Airbox mod???
14 Mar 2006 22:17
I remember reading one about a guy using 1 1/2" pool tubing in his box and deleting the cursed hella hard rubber.
- Biquetoast
- King Jeremy The Wicked
Re: Airbox mod???
15 Mar 2006 05:21
kz550krazy wrote:
Whoa - I think that's me. I was wondering what you meant when I first saw this thread...
Do you mean these?
Do you mean these?
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- OKC_Kent
Re: Airbox mod???
15 Mar 2006 07:37
I don't think that was you bique, but it looks pretty good. I remember the pool tubing deal.
If I recall correctly, it looked like clear tube with the fiberglass threads in it, and they clamped on the carb intake and were just shoved into the airbox holes, which had to be enlarged a bit. It seemed like a pretty cheap and effective way to get around the hard boot problems we sometimes have.
I found the thread in the archives and the pic is still up! It's called 'boot pain' and a guy named 2fastkawman did it.
[/quote]My Solution
I could not get mine to soften at all, used gas trany fluid vasoline ect. even boiling they wouldn't stay soft long enough. Nothing worked so I went to Home Depot and bought 12" of 2" reinforced pool tubing. Heated the ends in boiling water then put it on a bottel with the same size mouth as my carbs and cooled it with cold water. The air box side was just the right size to fit through the holes snugly.
Total cost $2.50
:cool:
[/quote]My Solution
Total cost $2.50
Post edited by: OKC_Kent, at: 2006/03/15 11:11
Cashion, OK
78 KZ650 B2 85,000+ miles
- OKC_Kent
- kz550krazy
Re: Airbox mod???
15 Mar 2006 22:13
Are those 1.5" Furnco fittings? Did you have to enlarge the two inner airbox holes for it to work? I think I am following this.....you just cut them in half and used the end with the lip on it inside the airbox?
