jet question again
  • irish mike
  • irish mike's Avatar Topic Author
  • 79 kz 650 b3 rat rod
jet question again
30 Jun 2009 20:04
#303508
hi again -im putting pod filters on my project-kz650-1979-from what i gather i need to go up 2 sizes-any body know what 2 sizes up from stock is-mikuni vm 24 ss-thanks mike
  • anarki650
  • anarki650's Avatar
Re: jet question again
30 Jun 2009 20:54
#303522
What exhaust are you running and what type of pods? The cheap pods don't flow as well as K&N so that'll make a difference for you. When I was running the stock vm24 carbs with K&N pods and lightly baffled 4-1 header on my 77 650 I was running 17.5 pilots, clips on the #4 slots, and 115 mains. No baffle I had to bump up to 117.5. On a stock exhaust 81 650 CSR (vm24 carbs as well) when I switched to pods I had to bump to the 17.5 pilots, needles on #4, and 112.5 mains. Stock jetting is 15 pilots, needles on the #3 clip (I think, that's where every rack of carbs I ever tore apart was clipped anyway), and optimally 102 mains (Kawi jetted them lean from the factory though and most had somewhere around 95 mains, which were just a bit lean).
Hope that helps!!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • Old Man Rock
  • Old Man Rock's Avatar
01 Jul 2009 04:55
#303569
"what i gather i need to go up 2 sizes-"
Be careful in this concept for it doesn't always hold true....
Example, I have brand new Keihin's CR specials and it was the opposite for me where the stock jets are running way too RICH!
I've had to drop mine 2 sizes in the Mains and slow jets (pilots) plus drop a clip position from 4 to 3...
Jetting is a pain in the ass no doubt but it is what it is... Trial and error, test, re-jet again when necessary...
What works on my KZ isn't necessarily going to be right on yours... To many other variables that effect this for the desired/ideal TAN plug coloring...
Just some thought...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • irish mike
01 Jul 2009 18:52
#303726
thanks omr-my airbox and my stock pipes are shot-just bought the bike-project-pipes have baffles ripped out -thinking abot bolt on dunstallsand pod filters[the cheap one for now untill up and running-would a jet kit from dyno jet be agood idea?im new to this whole jetting thing thanks mike.....
  • anarki650
02 Jul 2009 07:30
#303846
Jet kits are a waste of money. You'll spend probably 5 times more to buy the jet kit than you will picking up the jets you need from z1 or a local shop. The jetting numbers I gave you should get you real close.
09 Kawasaki ER6n
Omaha NE
  • irish mike
02 Jul 2009 15:48
#303928
thanks alot-i ordered the jets from jc whitney-10.99as opposed to jet kit 134.99 thans again ...mike
