newbie carb question, what are these?
- happyhubby
30 Jun 2009 10:56 #303370
by happyhubby
1980 kz550 daily driver
newbie carb question, what are these? was created by happyhubby
there are 2 open tubes on the inner line of the 2 outer carbs what are they and what should they connect to? it was like this when i bought it.
thanks, jacob
thanks, jacob
- Yojymbo!
30 Jun 2009 11:02 - 30 Jun 2009 11:10 #303374
by Yojymbo!
Replied by Yojymbo! on topic newbie carb question, what are these?
A vacuum line I believe. It doesn't attach to anything .
Last edit: 30 Jun 2009 11:10 by Yojymbo!.
- happyhubby
30 Jun 2009 11:04 #303376
by happyhubby
Replied by happyhubby on topic newbie carb question, what are these?
anyone know what they should connect to? ive looked and looked and there are no other open lines or disconnected spots.
- JMKZHI
- Thank you received: 48
30 Jun 2009 12:09 #303384
by JMKZHI
Replied by JMKZHI on topic newbie carb question, what are these?
Is that the airbox side of the #4 carb?
If so, then those are the vents & should remain open to the atmosphere. On my 81 650 the vent tubing is routed over the airbox shoulders, then fitted snugly between the airbox & side covers.
- fixer5000
- Thank you received: 5
30 Jun 2009 12:57 #303399
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic newbie carb question, what are these?
yup bowl vent for sure
massachusetts
