VM26 on a kz650 will i feel the performance???
- galaxian
29 Jun 2009 07:09
Like the subject says will i feel the benefits or running vm26 off a 1000 on my 650? Better yet should i and if so do i use 650 jetting in the bigger carbs or stock 1000 jetting that carbs came from?
1977 KZ1000A1, 1979 KZ650 C3
- anarki650
Re: VM26 on a kz650 will i feel the performance???
29 Jun 2009 07:12
Easy answer for that one, YES!!!
I'm running vm26 off a Suzi GS750 on my 77 650, it was a HUGE gain from the 24's. My jetting is the same as I was running in my 24's, with K&N pods and lightly baffled 4-1 I'm running 17.5 pilots, needles on #4, and 117.5 mains. I don't have any dyno or track numbers to tell you how much of a gain there is, but the seat of the pants knows the difference!!!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- 79MKII
- Love Them Kaws!
29 Jun 2009 09:45
That's good info. I have an extra set of 26's that I was thinking about putting on my 650 one of these days. I also have several sets of 28's (Z1 style) - think those would be too much for the 650?
The Kaw List:
- otakar
29 Jun 2009 09:49
If you put a 750 head on it with larger valves than the 28s would be fine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- anarki650
29 Jun 2009 10:17
One of the guys over on
www.kz650.info
put 28s on his stock 650, said they turned it into a wheelie monster. I'd throw some on mine if I came across them cheap, but when I scored the 26's there weren't any cheap 28's to be found...
The 26's will probably give you the best all around gain without getting into deeper motor work. The 28's would need some top end work to really get the most benefit from them (as noted)...
09 Kawasaki ER6n
Omaha NE
Omaha NE
- 79MKII
- Love Them Kaws!
29 Jun 2009 14:20
With everything being stock except for air filters and exhaust, it sounds like 26's are the way to go.
Anyone else have 26's (or larger)on their 650?
The Kaw List:
- gane
29 Jun 2009 16:02
78 kz650 b2/w720 wiseco kit. Jardine 4-1 K&N's.have run stock vm 24's in both a/s amd a/s/fuelmix screw configurations, kz1000 vm 26's and 29 smoothbores, 29's worked best, but having only 1 set the thou took presedence. sidebar, the 650 was my wifes' bike, and after Kid's, seldom saw regular use, thus multiple 24's, I kept a spare set cleaned & waiting in the event of a "lets' go now" ride. even at that, hard starting cold was previlant. perhaps I was inept, but w/ present vm 26's have had no probs tho bike often sits months unused. g
[img][/img] 1977 KZ1000A1
- galaxian
30 Jun 2009 07:03
i guess now i just need some rubber manifolds and some jetting specs.
- galaxian
30 Jun 2009 07:27
anarki650,
Can you post the link to the thread on kz650.info about the carbs that you mentioned. I looked for it but cannot seem to find that thread. Would be interesting for all i think.
