- Thank you received: 2098
Float bowl gasket?
29 Jun 2009 20:47 #303257
by Patton
Replied by Patton on topic Float bowl gasket?
Was floatbowl fuel level checked using the clear tube test?
The "measuring-while-upside-down-on-workbench" test is not reliable.
Good Luck!
Good Luck!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
30 Jun 2009 03:15 - 30 Jun 2009 03:17 #303303
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Float bowl gasket?
Patton wrote:
Propane eh... that I can do.
Patton wrote:
Yeah. Its so easy on these carbs, I always do the level installed on prime.
With the way these carbs are designed, at idle, the throttle plate is stopping almost all vacuum flow in the bore. I've checked several times now, and the plate is passing air exactly as the others. So the point of entry has to be after that plate...
small pilot circuit holes after plate... I've tried plugging the air screw passages completely...
carb holder leak/crack...
maybe my spark plugs bad/leaking!?! huh!?
exhaust flange is really tite and quiet...
More to try I guess. Pretty sure this carb isnt just busted. Will update...
Try spraying around #2 carb with propane gas (unlit of course, duh) while the engine's running. Gives broader coverage than spraycan method with WD40 or carb cleaner.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Jun 2009 03:17 by TeK9iNe.
- TeK9iNe
30 Jun 2009 19:27 - 30 Jun 2009 19:28 #303501
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
OK, I've finally fixed my problem. -Only beacuse I'm crazy relentless.
I was actually unaware that there are three tiny jets in the throttle end of the carb bore, and the most important of course was clogged.
Even after boiling and everything, it wasnt gas/varnish buildup. It was a tiny flake of glass!?! Glass... wha? Yeah, glass. :laugh:
I have no idea where that came from. :huh:
Evrything else is so crystal clean on this thing...
No boot leak, or anything like that.
One more question to anyone who has more experience with these carbs. The air screw guys on the top engine side, do they pass mixture, or just air? Is in rich, or out?
Anybody? ...Otakar?
Cheers.
Anybody? ...Otakar?
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Jun 2009 19:28 by TeK9iNe.
- gane
- Thank you received: 1
30 Jun 2009 20:08 #303511
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Float bowl gasket?
tec9, Sorry, am clueless. screws between slide and head below carb throat are usually fuel mixture screws. and control volumne. (mix being controled via pilot jet) Diaphram (CV) carbs use several configurations incorperating jets located in body below diaphram. In old yamaha's these were similar in external dimension but radically different in orifice size. can only offer, chase passages and compare jets to other bodies. luck G
- Yojymbo!
30 Jun 2009 20:16 #303514
by Yojymbo!
Replied by Yojymbo! on topic Float bowl gasket?
THIS THREAD HAS BEEN MURDERED BY YOJYMBO!
- TeK9iNe
30 Jun 2009 21:02 #303523
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Yojymbo! wrote:
OK...
Thanks gane.
OK...
Thanks gane.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
