Will Mikuni VM22SS Carbs work on 1980 KZ750E bike?
- TJMD
26 Jun 2009 13:53 #302282
by TJMD
Will Mikuni VM22SS Carbs work on 1980 KZ750E bike? was created by TJMD
OK_I'm on the cheap,and I no longer have my KEIHIN CV34 carb rack.What I do have is (if I can get the pics in) a rack of MIKUNI VM22SS carbs.I had these in a box in my garage and what was written on the box was: "Original 1978 KZ650 D1A SR Original Carbs(need cleaning)".I sold this bike a couple of years ago,but when I bought it the carbs were green,so I bought a used set off a running bike from a dude on ebay for cheap and put those on.These I stored.Why I think they are VM22SS,is because I also have(still),the owners manual,and it says that that is what they(kawa) used on the bike.Will these work on my 1980 KZ750E? Jeff at Z-1 directed me to some intakes that were 24mm-he said that I could use these.I noticed that the intakes had vacuum plugs on them(as opposed to on the Keihins-they were on the carb bodies.)I guess I will have to use pod filters,since the airbox side is way different.No prob. Anybody know anything about the throttle cable(need different?)I am using stock handlebar.Also-I have cleaned 3-4 sets of the CV 34s,and they are pretty straight forward to clean and dissasemble,but I never did any of these.Is there anything to watch out for on these, and/or does anybody know of any literature available for dissasembly on these? THANX TO ONE AND ALL!
- anarki650
- Thank you received: 5
26 Jun 2009 15:18 #302295
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Will Mikuni VM22SS Carbs work on 1980 KZ750E bike?
I don't know anything about the CV carbs, so can't speak to the throttle cables. But if those are vm22ss carbs I would think you'll notice a HUGE drop in performance. The 22's are tiny for the 650s (most 650s came with 24s) so I would really think they'd be way too little carb for a 750.
Jeff was right, you'll need the carb holders he told you about, the vacuum ports on them are for syncing. The vm series carbs are really easy and straight forward. Check out www.kz650.info for several detailed write ups on how to tear them down and bench sync and what not.
09 Kawasaki ER6n
Omaha NE
- TJMD
26 Jun 2009 15:24 #302297
by TJMD
Replied by TJMD on topic Will Mikuni VM22SS Carbs work on 1980 KZ750E bike?
THANX for that.If I can't find any CV34s for the 'ole Red Rat I might try them-just to run this bike.I hate to be w/o a runner.
