What is a good carb to replace my BS34s
- Buda
24 Jun 2009 05:43
What is a good carb to replace my BS34s? I want to try something simpler than the BS34s but I dont want to pay a mint for a set.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- Z1109R Fin
Re: What is a good carb to replace my BS34s
24 Jun 2009 08:12
Simpler that BS34´s :blink:
They don´t get much simpler, do they? I mean adjusting mechanical flat- or roundslides is more complicated and ad in acc. pumps...
Z1000R ´83...Slightly modified...
- otakar
24 Jun 2009 08:18
Z1109R Fin wrote:
I 100% agree nothing much better. Once I went to BS34s I would only change to fuel injection. Manual carburetors are much more difficult to work with, and in comparison to BS34s very unforgiving. I run BS34s on a stock 81 kz1000 motor and I can get the wheel off the ground while shifting from first to second. Engine is stock, carburetors have been modified to be able to run with pod filters.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- tachrev
- Rubber Side Goes Down
24 Jun 2009 08:50
Looking to hang on to your BS34's too?
I have a set of VM26's on the bike I'm riding now, with new manifolds and new pods. No accel pumps. Pretty straightforward.
Is that the kind of carb your looking for? I'll trade ya!
Build Thread
Build Thread
- Buda
24 Jun 2009 15:10 - 24 Jun 2009 15:17
Ill start with I dont know much about carbs. So what your saying is I cant do much better than what Ive got. Ive got a flat spot from 6 to 7000 rpm, at 7000 it just screams and it has enough low end to pull the front wheel roling in first gear. Where do I start to get rid of the flat spot?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 24 Jun 2009 15:17 by Buda.
- otakar
24 Jun 2009 16:22
I would be willing to bet that you are running pods on a stock set of carbs. This being said, I can say that the carbs must be modified to be able to handle the pods. This requires some minor machining, new needles, and rejeting. I had the exact same problem with mine until the modifications were done. These can cost anywhere from $300 to $650 dependent on who performs them for you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
24 Jun 2009 16:35
Ive already spent almost $400 on them, being rebuilt and jetted for the pods another $300 that is alot of money on one set of carbs.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
24 Jun 2009 16:53
Than the person who did the work should be responsible for the proper operation. Did they replace the needles on them?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
24 Jun 2009 16:55 - 24 Jun 2009 16:56
The biggest problem is when people do not know what they are doing and over jet the top end and neglect the mid range. This is a very common problem. Anyone we know, do the work?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Jun 2009 16:56 by otakar.
- otakar
24 Jun 2009 17:03
A well set up set of BS34s should be as good as a set of well set up set of 31mm Smooth bores.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
