KZ650 guys with 4-1+ pods.... what needle setting?
- caffcruiser
22 Jun 2009 21:19 - 22 Jun 2009 21:46
Runnin 117.5 mains and 22 slows IIRC, the pods are Uni filters, so they breathe well, and I don't know what the header is, but it gets plenty out.
Bike is definitely not running nicely though, and I realized I forgot to check this.
What needle setting are you running with your bikes setup similarly?
I'm in the upper midwest.
Last edit: 22 Jun 2009 21:46 by caffcruiser. Reason: meant 117.5, not .4. Sorry.
- caffcruiser
Re: KZ650 guys with 4-1+ pods.... what needle setting?
23 Jun 2009 19:22
So I'm the ONLY GUY running pods AND a 4-1 on this forum.
Awesome.
Thanks for the help dudes.
Awesome.
- cmmman
23 Jun 2009 19:26
i have VM24SS carbs with 110 main and 17.5 pilot. Engine is stock 650 with emgo pods and yoshimira 4 into 1. Seems to run pretty good.
1977 KZ650B, modified.
- anarki650
23 Jun 2009 20:25
On my 77 kz650 I have K&N pods on vm26 carbs (size bigger than stock) with a 4-1 lightly baffled pipe. I'm running 17.5 pilots, 117.5 mains, with needles on the #4 clip. When I was running stock carbs my jetting was identical. Hope that helps.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- anarki650
23 Jun 2009 20:27
Also, I was anal when I jetted my carbs and went through about 10 sets of plugs doing plug chops on all 3 circuits (idle, about 3500 rpm, and WOT) so I'm very sure that my jetting and nice and tan plugs are both accurate for all ranges of the rpm band.
In Omaha, NE if you wanted to know my atmospheric pressure.
09 Kawasaki ER6n
Omaha NE
Omaha NE
- caffcruiser
23 Jun 2009 20:36
Thanks for the specific info. Check your PM's man.
- caffcruiser
23 Jun 2009 21:31
Oh, and I guess a better question would be.... is the stock setting in the 4 position?
I seem to remember it being.....
- anarki650
23 Jun 2009 21:38
Every rack of 24's I've ever pulled apart for the first time (that I did it) the needle was in the #3 slot, don't know if that means that was the stock setting or not, but that's what I always found when I opened them up...
09 Kawasaki ER6n
Omaha NE
Omaha NE
- caffcruiser
23 Jun 2009 22:07 - 23 Jun 2009 22:08
I'll definitely have to check.
I went out and pulled the needles from two spare sets a bit ago and found both in the #4 position already.
I'll tear into my good carbs tomorrow.
The bike is just SUPER CHOPPY at idle... but will idle with the choke up.
It sorely needs to be synced up, but I wanna get this setup first.
Thanks man.
Thanks man.
Last edit: 23 Jun 2009 22:08 by caffcruiser.
23 Jun 2009 22:19
Jet needle clip position has very little, if any, influence on idle performance.
Good Luck!
Good Luck!
- caffcruiser
23 Jun 2009 22:33
You're right.... but getting the proper needle setting ahead of time before you sync up a set of carbs is common sense. Note: Nowhere in my post did I say I plan to change clip position to cure idle. Just that it idles like piss and needs to be synced, but that I wanted to get this set ahead of time before I go through all the setup.
