- Thank you received: 1
VM22 vs VM24 Carbs
- spudbudy
- Kick it like you mean it
21 Jun 2009 15:15 #301128
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
VM22 vs VM24 Carbs was created by spudbudy
Ok here it the information the I have tracked down and now it makes perfect sense why some people are running bigger jets then others.
Attachment KZ_Carbs.txt not found
