- Thank you received: 7
bs34 float synch
- toad
21 Jun 2009 08:22 #301067
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
bs34 float synch was created by toad
so to get the floats correct I should use the test tube method and make sure the gas is 1/8 below gasket and if not I have to take carbs apart and bend float tang accordingly then reassemble and check again.So if its out I just keep taking the float bowls off again and again to get it correct?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- timebomb33
- Thank you received: 10
21 Jun 2009 14:09 #301111
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic bs34 float synch
i try to lay them over a bit on there side so that the float adjusting tangs are just touching the plunger on the needle then i try to set them a sguare as possible that usally gets them close the ideal is to measure them to spec but if you set thm so that there sguare then it should be close unless you have weak springs in the needle itself then it's time for a replacement you can buy those seperately.
