Boiling carbs
- RIDEzx6r
Also as far as lemon juice goes I can use just normal 100 percent lemon juice from the grocery store or does it need to be some specific kind?
- boots
Thanks
Boots
present bikes 1976 KZ900, 1978 KZ650 Past bikes Too many to remember!!Mostly Kawasakis and a few Sportsters
81 cb650
- jtmcculloch
Clean carbs in a pot of boiling water & lemon juice. The acidity from the lemons eats through everything - gas varnish, oil build up, dirt, grime, etc. Just remove the bowls, remove the caps, then drop everything into the pot and let it sit for 20 minutes (rotate them a few times). Rinse well with clean water and blow dry.
76 KZ1075
93 ZR1100
71 Moto-guzzi 750
2001 ZR-7S
- RIDEzx6r
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Mortarmanmike
Also, somebody told me that instead of lemon juice which has sticky sugars in it to try ascorbic acid. Ascorbic acid is the same thing as citric acid which is whats really doing the cleaning. Evidently ascorbic acid can be bought at pharmacies but I haven't tried to find it yet. Supposed to be cheaper too but I may just say to hell with it and use lemon juice. I guess as long as you rinse it well it shouldn't matter.
1979 KZ1000 Shafty
- AraneaeFatalis
Did ya'll remove the floats or just leave them on? Think I'm gonna try this this week.
I'm curious to know this too, mine need a good cleaning and I was thinking of boiling them, but I need to know what needs to be removed or what can stay, etc.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Yojymbo!
If you're going to strip them down why not use some xylene and toluene? I hooked up a back massager to a closed SS pan and let the carb bodies soak for 2 days and they looked new. Filter the solvent through a coffee filter when you're done to get rid of the chunks and you can reuse it to soak your next grimey item.
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
WARNING:
Both xylene and toluene are known carcinogens (cancer causers) as well as highly toxic and highly flammable so extreme care should be used in handling both of these chemicals. Proper protective gear must be worn and suitable ventilation precautions must be taken when using either/both these chemicals.
Additionally, both of these chemicals are classed as hazardous goods AND as VOC's (Volatile Organic Chemicals) and thus are NOT easily available to the average Joe in most jurisdictions.
You've been warned.....
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
