so to get the floats correct I should use the test tube method and make sure the gas is 1/8 below gasket and if not I have to take carbs apart and bend float tang accordingly then reassemble and check again.So if its out I just keep taking the float bowls off again and again to get it correct?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
