80 550 LTD carb question
- supergenius74
18 Jun 2009 18:09 #300422
by supergenius74
80 550 LTD carb question was created by supergenius74
just finished a "restore" of my favorite bike from highschool. It was a 50 dollar basket case that I ended up putting a new 4 into 1 pipe and K&N pods on the TK carbs. After she warms up it idles pretty good and drives fine till about 1/2 throttle and leans out. Still has the stock jets in it and I am looking for a ballpark on a main jet size to go to for this setup. thanks, shane.
- larrycavan
- Visitor
18 Jun 2009 19:01 #300442
by larrycavan
Replied by larrycavan on topic 80 550 LTD carb question
Great little bikes but the early ones had carb issues. The TK carbs were a shot term deal with Kawasaki. I think it was 83 they moved to CV carbs on the 550.
Put the airbox back on it. Before you do, see if the relief plates in the choke plates are all still there. They sometimes came loose and got sucked through the motor.
If you're heart is set on pods, you can try Mikuni main jets. Best bet for all around is just put the airbox back on it.
JMO
JMO
- supergenius74
21 Jun 2009 12:50 #301089
by supergenius74
Replied by supergenius74 on topic 80 550 LTD carb question
i don't have the original airbox, nor a lot of other parts, this was a basket case that i put back together and decided to do pods and 4into1 since it had neither intake nor exhaust with it. i have links for the jets, just looking for a recomended size for this setup. thanks.
- timebomb33
- Thank you received: 10
21 Jun 2009 12:55 #301090
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 80 550 LTD carb question
go about 3 or 4 sizes bigger and raise your needle heights by at least one clip or if they arent adjustable put about a one mm thick spacer washer underneath the clip it will richen the mid-range up quite a bit probably enough to get over your stumble.
- supergenius74
22 Jun 2009 09:34 #301331
by supergenius74
thank you timebomb!
