- Thank you received: 1
Air box ducts
- spudbudy
- Kick it like you mean it
18 Jun 2009 15:14 #300340
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Air box ducts was created by spudbudy
After changing my air filter I just now realized that the 1 & 4 ducts are curved does anyone know which direction there are supposed to be facing? up down toward each other or away from each other? or doesn't it matter? I figure since they are curved there must be a certain direction that they must face. Still searching for the perfect solution. Thanks
- kawsakiman
- Thank you received: 6
18 Jun 2009 15:27 #300359
by kawsakiman
Replied by kawsakiman on topic Air box ducts
there should be little alignment tabs/dots or what ever there called on the airbox.
there should also be a little cutout of sorts on the ducts.
just align the marks up.
- spudbudy
18 Jun 2009 19:15 #300447
by spudbudy
Replied by spudbudy on topic Air box ducts
Thanks I'll have to look don't think I ever seen the little notches but never looked before either.
- Bluemeanie
- Thank you received: 14
18 Jun 2009 21:50 - 18 Jun 2009 21:51 #300491
by Bluemeanie
Replied by Bluemeanie on topic Air box ducts
The outer ducts will curve in towards the air filter and can go on either side. Check out pic of aligning tabs...
Last edit: 18 Jun 2009 21:51 by Bluemeanie.
- spudbudy
19 Jun 2009 08:12 #300570
by spudbudy
awesome pic i'll check it out later today as it'pouring like a b*tch here today
- spudbudy
21 Jun 2009 15:04 #301123
by spudbudy
Bluemeanie thanks for the photo it helped yes I see the alignment tabs now never saw them or looked before THANKS
