81'' KZ1100 CARB REBUILD
- Tedster
17 Jun 2009 21:15 #300088
by Tedster
81'' KZ1100 CARB REBUILD was created by Tedster
Hello
i have an 81" KZ1100 and need to rebuild the carbs
i know these can be expensive to rebuild i haven't took all the tops off yet just one the diaphram looks good,i was told not to use spray carb cleaner on the diaphrams a guy told me to go to nappa auto and buy the gallon of cleaner with the part holder in the can said it was some of the best cleaner out there it should be for over $25.00 a gallon,where is the cheapest place to buy the kits and the seals, on the transfer tubes you just need the o-rings replaced correct.
the diaphrams can be reused as long as there are no holes or rips or anything on them right
thanks ted
thanks ted
- Tedster
18 Jun 2009 10:05 #300259
by Tedster
Replied by Tedster on topic 81'' KZ1100 CARB REBUILD
does anyone know where to buy a complete kit on line reasonable,with the diaphram gasket also,and the O-Rings
for the transfer tubes
Ted
Ted
- timebomb33
- Thank you received: 10
18 Jun 2009 11:09 #300276
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 81'' KZ1100 CARB REBUILD
try sudco
- austin3119
- Thank you received: 7
18 Jun 2009 12:18 #300290
by austin3119
Replied by austin3119 on topic 81'' KZ1100 CARB REBUILD
What carbs are on the 81 kz1100?
- Thank you received: 2237
18 Jun 2009 13:02 #300304
by TexasKZ
Replied by TexasKZ on topic 81'' KZ1100 CARB REBUILD
FI, methinks.
18 Jun 2009 13:11 #300307
by TexasKZ
- Tedster
18 Jun 2009 15:21 #300347
by Tedster
i am not sure really they have the square top with spring under the cap with diaphram on the slide,they look about like a 34mm idon't no how to send pics thru the forum only emails i am not very good on a computer
Ted
Ted
- timebomb33
18 Jun 2009 15:24 #300353
by timebomb33
they are bs 34's
- Tedster
18 Jun 2009 15:57 - 18 Jun 2009 16:00 #300382
by Tedster
is there anywhere to buy the whole kit for rebuilding them,theres a guy on ebay that is in canada he has the lower kit for 49.95+7.75 but they can't ship till tues. and as bad as our oconomy is i would rather spend my money here,is there a cheaper place than z1 enterprise and i guess they ain't all so bad there like 20.75 a carb but all i seen was the lower,i would like to do the whole carb including the 0-Rings on the transfer tubes,
i only want to do this once,i only looked at one diaphram and it looks good hopefully the other 3 are ok
Ted
Ted
Last edit: 18 Jun 2009 16:00 by Tedster.
- timebomb33
18 Jun 2009 16:03 #300385
by timebomb33
our economy is bad up here to but most kit's i've ever seen included just the carb guts not the individual o-rings you will most likly have to order those seperatly.
- Tedster
18 Jun 2009 16:10 #300388
by Tedster
is z1 enterprize about the reasonablest or is there a cheaper place do you know
Ted
Ted
