- Thank you received: 1
No high RPM when using choke
- spudbudy
- Kick it like you mean it
17 Jun 2009 18:28 - 17 Jun 2009 18:33 #300013
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
No high RPM when using choke was created by spudbudy
Ok, call me an idiot but I have had these carbs apart so many times its not funny. So here is my setup vm22's pilot jet#1 =50 pilot jet #2=15 main jet 95 needle clip #5. So I just changed out my old paper air filter last one was real bad now it appears that when I go to start the bike cold I get no high RPM it used to goto @2500 now hardly climbs at all. When I first got the bike 28 years ago the RPM used to goto @4000. Not really sure what changed. all of the valves are within spec. timing is spot on carbs are synced idles smooth and runs just fine. I can't believe just changing the air filter is enough @ idle to make the choke circuit work that much better. I understand its now leaner then it was but what could I be missing? I just now re-synced the carbs and got 28cm on morgan carbtune so I know that's not the problem. I'm not sure but I don't recall and seats on the plungers I think they were all brass. Any suggestions would be SUPER!
Last edit: 17 Jun 2009 18:33 by spudbudy.
- Locozuna
17 Jun 2009 18:41 #300020
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic No high RPM when using choke
Are you sure the new filter is seated correctly in the airbox? If you somewhat restrict the airbox with your hand do the rpms climb?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- spudbudy
17 Jun 2009 19:40 #300049
by spudbudy
Replied by spudbudy on topic No high RPM when using choke
I haven't tried that next time I start it I will try that suggestion thanks
- spudbudy
18 Jun 2009 15:06 #300331
by spudbudy
tried starting it with a rag covering the opening wouldn't start at all duh. tried the hand didn't work rpm the same. tried to resync the carbs same results not sure what changed but it did.
- HerrDeacon
18 Jun 2009 15:46 - 18 Jun 2009 15:46 #300373
by HerrDeacon
Replied by HerrDeacon on topic No high RPM when using choke
When it does run on the choke are any of the cylinders not running? Check the header pipes to see if any are cold. I had a similar issue and one of the cylinders was not running on the choke, turns out the float bowl circuit that feeds the enrichener tube was blocked (float bowl gasket material punchout fell in the hole) so that carb wasn't getting fuel on the choke.
Best of luck finding the problem.
Last edit: 18 Jun 2009 15:46 by HerrDeacon.
- spudbudy
18 Jun 2009 19:13 #300446
by spudbudy
carbs are clean checked the firing using colortune works great. thinking this may have something to do with my sync vacuum level being too high don't know just a thought.
- spudbudy
21 Jun 2009 15:09 #301126
by spudbudy
DUH ! DUMBA** me somehow adjusted the PMS out too far. wasn't paying attention to what I was doing you know hot day COLD beer. anyway its all better now
