- Thank you received: 7
bs34s eratic behavior
- toad
16 Jun 2009 18:33 #299735
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
bs34s eratic behavior was created by toad
got my bs34's in my kz900 today 37.5 pilot and 140 main jet.I dont have my filters on it yet and took it for a little ride. It idles up and down and when riding takes a few seconds or more for the rpm;s to come down .Is this because of the pods missing or do you think its dirty again,float levels, I checked for vaccume leaks.My other carbs 26mm were fine.Also I cheked the slack in the cable was fine .Could it be a pilot jet,please help:S
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- otakar
16 Jun 2009 18:55 #299747
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic bs34s eratic behavior
If it takes a while for the idle to drop is usually indicative of idle being too lean. Try to adjust the Idle screws first before changing jets. This will also improve low end response.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- toad
16 Jun 2009 18:58 #299749
by toad
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Replied by toad on topic bs34s eratic behavior
I cant find them are you talking about the air mixture screws?Dont I have to drill something out to uncover them?
thanks
thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- brianrae33
16 Jun 2009 21:32 #299803
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic bs34s eratic behavior
same carbs on my 82 ltd1000 adjusted my throttle cable and it works perfect..
1982 kz1000ltd
