- Thank you received: 1
Help with this bogging
- Alex_KZ1K
Oh, I haven't been able to syncronize them... I found out that ordinary vacuum gauges don't work for this application... they broke. They were jiggling so wildly back and forth that they all broke. :blush:
- RomSpaceKnight
- Thank you received: 2
- Alex_KZ1K
- OKC_Kent
- Thank you received: 20
You need to have some kind of damping system if you use ordinary guages. It lessens the pulsing. If I get a picture of the one I built I'll post it. It's just PVC pipe. Works good.
Post edited by: OKC_Kent, at: 2006/03/10 23:03
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- The Fish
- Thank you received: 6
Did you do any pre storage before storing (stabil in the tank? ) You may need to re clean your carbs. If the bike is getting too much fuel, that where I would start. If they are C/V type carbs the slides may be stuck open also.
Fish
- Nevco48
- Thank you received: 3
- rammy
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- gas
I just ran into the same problem this last weekend.Only other thing that is different from you problem is that my bike only sat for 3 weeks or so.I found that i had a spark plug go south on me cause a really bad miss and though it was something i had done re;cleaning the carbs.changed the 1 plug and it all cleaned up and down the road I went .So I would start with the easy things first.(new plugs)and go from there. Good luck
A new fuel filter wouldn't hurt either.
- fergyfer
How did you fix the fuel leaks...?
- Alex_KZ1K
Alex, the first thing you said was "OK, I fixed the fuel leaks". When did you do this, and was it running good before you fixed the fuel leaks?
Well, when I said that I hadn't actually taken it for a ride yet. The t's that feed the carbs were leaking, so I seperated the carbs and wrapped them in teflon tape. It was starting up and idling fine before I messed with the pilot screws.
- fergyfer
Above, you mentioned about trying to sync your carbs. Was this after you fixed the leaks?
Last thing you said in your reply to me was "it was starting up and idling fine before you messed with the pilot screws". When did you mess with the pilot screws? After you fixed the leaks or before? And, if it started and idled fine before you messed with the pilot screws, why were you messing with the pilot screws?
- Tower_Monkey1
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
