need help
- abeall2
14 Jun 2009 13:34 #299122
by abeall2
need help was created by abeall2
i just bought my first kz, an `80 650 thats in great shape however i have a little issue. on the side of my carb there is an exposed brass tube that puffs out air every now and again and it also has vacuum while the bike is running. i have attached a picture of it.
- Thank you received: 2098
14 Jun 2009 13:52 - 14 Jun 2009 14:52 #299130
by Patton
Replied by Patton on topic need help
Might be nipple for tube to vacuum petcock. But if not, plug it with a vacuum cap.
Should be no vacuum nipples sucking in from open air.
Good Luck!
Here's an example of manual slide carbs.
[Click on image to enhance view]
Good Luck!
Last edit: 14 Jun 2009 14:52 by Patton.
- abeall2
14 Jun 2009 14:49 #299138
by abeall2
Replied by abeall2 on topic need help
yea the petcock was redone by the guy who i bought it from its a newer stainless steel petcock so its possible he just didnt plus the vacuum nipple thanks a bunch ill try pluging it and see how she runs
14 Jun 2009 15:02 - 14 Jun 2009 15:08 #299142
by Patton
Sounds like the oem vacuum petcock was replaced with an after-market manual petcock, in which event the manual petcock doesn't need any vacuum supplied from the carb.
So the now unused carb vacuum nipple should be capped (plugged).
Good Luck!
Good Luck!
Last edit: 14 Jun 2009 15:08 by Patton.
14 Jun 2009 15:06 #299145
by Patton
Would also be sure to fit an accessory in-line fuel filter. These in-line filters are inexpensive and readily available at bike shops and at Z1E.
If needed, Z1E also carries the good heavy duty vacuum caps in a set of five.
Good Luck!
Good Luck!
- Thank you received: 2829
14 Jun 2009 17:04 #299162
by 650ed
Replied by 650ed on topic need help
I can't see the picture. Ed
- abeall2
14 Jun 2009 18:08 #299177
by abeall2
yea it was too large but i got a little cap and a filter for it today, thanx for the advice. I'll post some pictures of her later.
