Leaking Carbs
- supermandan713
08 Jun 2009 23:41 #297612
by supermandan713
Leaking Carbs was created by supermandan713
I am brand new to my kz, and motorcycles in general, but after cleaning up an old 1977 650 and starting it up, my #4 carb is leaking and will occasionally spit gas and sometimes my #1 carb leaks. can anyone help me out?
- timebomb33
- Thank you received: 10
09 Jun 2009 00:23 #297617
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Leaking Carbs
float valve assemblies will need to be replaced or at least polished. i would go with replacement as the polishing is only a temporary fix if it works at all.
- baldy110
- Thank you received: 512
09 Jun 2009 20:37 #297893
by baldy110
Replied by baldy110 on topic Leaking Carbs
First off where are they leaking from? The float bowl seal, overflow tube transfer tubes, etc.
- Bluemeanie
- Thank you received: 14
09 Jun 2009 21:07 - 09 Jun 2009 21:09 #297910
by Bluemeanie
Replied by Bluemeanie on topic Leaking Carbs
If you have a few bucks laying around (don't we all? :blink: ) order up a set of carb kits. This should fix three possible leak sources. Do one carb at a time with a thourogh cleaning (all passages) and new gaskets and float assemblies. Depending on the kits, do not use their metering rods, reuse your old ones. Set your float level (wet method) and she should be fine.
Last edit: 09 Jun 2009 21:09 by Bluemeanie.
- supermandan713
09 Jun 2009 22:04 #297949
by supermandan713
Replied by supermandan713 on topic Leaking Carbs
how expensive are a set of carb kits? and do you have any idea of where I can purchase one?
- supermandan713
09 Jun 2009 22:07 #297950
by supermandan713
I think they are leaking from the seal and also somewhere from the bottom of the float bowl
- kaw74z1
- 0 to 60 in 15 minutes.
09 Jun 2009 22:10 - 09 Jun 2009 22:12 #297951
by kaw74z1
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Replied by kaw74z1 on topic Leaking Carbs
Try
z1enterprises.com/
B)
Last edit: 09 Jun 2009 22:12 by kaw74z1.
- Bluemeanie
10 Jun 2009 06:03 - 10 Jun 2009 06:05 #297983
by Bluemeanie
supermandan713 wrote:
Here is what you need from Z1 Enterprises (Remember, you need four) This is THE place for most everything you need for your bike.
Last edit: 10 Jun 2009 06:05 by Bluemeanie.
- chrispysaki
10 Jun 2009 13:41 #298058
by chrispysaki
Replied by chrispysaki on topic Leaking Carbs
Sorry to jump in on your thread, but I'm having the same problem with a 80 KZ750, except they were not leaking at all until I cleaned the carbs (for the second time).
The first time I cleaned them I forgot to do anything with the air adjustment screw, so I don't know if that could have something to do with it. I tried tapping lightly on the float bowl, but I'm also having some other problems with the bike, so the leaking bowls wasn't a focus of my concerns. Maybe just try tapping them harder?
- mtkawboy
- Thank you received: 16
10 Jun 2009 14:12 #298063
by mtkawboy
Replied by mtkawboy on topic Leaking Carbs
Ive fixed transfer tubes by splitting the carbs and wrapping them with teflon tape and pushing them back in and putting the carb rack back together
