Stumbling...not entirely sure what's going on
- ghunt81
I went about 10 miles and filled up with gas, then rode close to another 40. When I was less than two miles from home, I took off from a stop light and the bike stumbled and seemed to misfire a few times, then was ok (i was using light throttle). It did it two more times after that, and then I was home.
Not entirely sure what happened...plugs and wires are fairly new and the plugs were clean when I pulled them to check.
Do these things even have a fuel filter or is there a screen in the petcock or something? Wondering if I need to check that.
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
I had a lot of rust in my KZ750 tank that clogged my carbs several times--even with an inline filter. I cremed the tank, and now have no more rust in the carbs.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
- nads.com
- Thank you received: 20
There is a filter it's for noise not fuel. The screen may or may not have been in the bowl, i'd have to see it. U might need a new battery, but take some nyquil.:woohoo:I took my bike out today for a ride.
I went about 10 miles and filled up with gas, then rode close to another 40. Shouldn't be filling your body with gas. When I was less than two miles from home, I took off from a stop light and the bike stumbled and seemed to misfire a few times,You have to be on the bike when you leave a stop sighn! then was ok (i was using light throttle). It did it two more times after that,It's gonna stumble cuz it was laying on it' side. and then I was home. Was this a dream?
Not entirely sure what happened...plugs and wires are fairly new and the plugs were clean when I pulled them to check. What kind of mp3 player is that?
- nads.com
- nads.com
And they want to legalize that stuff!@:woohoo:Could be that when you filled up with gas, you flushed some rust from your tank down into your carbs.
Grant.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- ghunt81
Anyway the battery is brand new so I'm fairly certain that's not the issue.
Also the tank doesn't look like it has any rust inside. Maybe I'll see if I can drain the tank and check out the petcock.
There is no inline filter that I can see.
- fixer5000
- Thank you received: 5
1978 kz650b pretty much stock
massachusetts
