\"rigging\" question
  • DanOz7Five0
  • DanOz7Five0's Avatar Topic Author
09 Mar 2006 18:40
#29707
I have a new petcock on the way. My old one was leaking pretty bad tonight at the bottom where the screen is. Its a simple on off reserve type, no vacuum or prime. What is a better temporary fix, teflon tape or Permatex black silicone? This fix should only have to last a couple more days.
  • RonKZ650
  • RonKZ650's Avatar
Re: \"rigging\" question
09 Mar 2006 19:48
#29720
Silicon is no good sealing gas, so I doubt it would work. The thread sealer tape may work. The original bowl had a rubber gasket in it which is no doubt missing or hopelessly hardened.
  • steell
  • steell's Avatar
09 Mar 2006 21:59
#29764
Permatex non hardening gasket cement should do it.
  • OKC_Kent
  • OKC_Kent's Avatar
10 Mar 2006 05:54
#29819
Teflon tape will not work with gasoline, please don't try it. It will eat it up and then you are back where you started, but this time with teflon goop blocking your fuel filter or carb .
Cashion, OK
78 KZ650 B2 85,000+ miles
  • jarhead
  • jarhead's Avatar
10 Mar 2006 14:25
#29936
Dan, if you need one to make the ride tomorrow, I'll give you one. Give me a call and I'll go to the shop tonight and pull one off of a tank.
