Carb Sync
- Darkangel
03 Jun 2009 19:43 #296165
by Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Carb Sync was created by Darkangel
ok I have open headers for exhuast i am going to baffle them, and I just bought pods for the carbs, and I want to sync my carbs....
Ok...Will I have to get a jet kit, or can i just sync them, and be good...Also Can I just a regular vaccum meter to check the vac off the carbs...instead of buy really expensive carb sync tools.
- Z1109R Fin
- Thank you received: 1
04 Jun 2009 04:15 #296231
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Carb Sync
Synching and jetting are two different things.
Synching means adjusting slides or butterfly valves in order to have equal vacuum in all carbs thus making engine run as smooth as possible.
Jetting is done to achieve correct Air/Fuel -ratio per engines requirements.
- Darkangel
04 Jun 2009 06:30 #296250
by Darkangel
Replied by Darkangel on topic Carb Sync
So when do I know I need to rejet
- Z1109R Fin
05 Jun 2009 03:18 #296447
by Z1109R Fin
Jetting and A/F -adjustment are needed if you change some parts of motor set-up. This can be f.ex. pod air filters, changing exhaust etc.
Please SEARCH this forum first. Use words like carburettor, jetting etc as there´s a lot and I mean a LOT topics on this subject. And a lot more things to eard before starting to rejet.
This might also be intresting for starters:
www.mikuni.com/fs-tuning_guide.html
www.keihin-us.com/am/tuning/
- Old Man Rock
- Thank you received: 225
05 Jun 2009 05:03 #296458
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Carb Sync
For carb iniital setup & synching once you get to this point....
Gunston Color Tune for Pilot Adjustments...
www.etoolcart.com/gunson-colortune-14mm-...lug-19-4074-100.aspx
The Morgan unit is the way to go...
www.carbtune.com/
OMR
www.carbtune.com/
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzr750r1
- Thank you received: 9
05 Jun 2009 07:23 #296488
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic Carb Sync
Found a bit of detail on the colortune gizmo... Thanks for the suggestion OMR. Pretty cool little tool here.
www.ldrider.ca/techpages/colortune.htm
- dman3998
05 Jun 2009 22:19 #296675
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Replied by dman3998 on topic Carb Sync
THAT color tune is a way cool tool. takes the guess, I'm close enough right out of it. think I will get one coming. I have a hard enough time getting it right on a single cylinder!.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
