What's causing a popping sound from tank/petcock?
- nob_1100
If I touch the petcock I can feel the beat. I also see the gas flow in the fuel line pulsating at the same rate. I have never seen (heard) this in the half dozen bikes I've owned although none were as large as 1100. Does anyone experience this? Is there a fix?
83 1100 Ltd
- dman3998
you got that Travelocity Gnome in your tank and he is sending Morse code trying to get someones attention to let him out.
you need to to cut a big hole in your tank and let the little guy get out.
If you dont, we will report you to the SPCG, That's the Society for the prevention of Cruelty to Gnomes.:S
Sorry, just came to me. have never heard of a problem like yours. pretty strange.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- Thank you received: 2098
Thinking cap vent might be clogged.
Good Luck!
- nob_1100
SO! your the one thats got him!!!!
LOL. Wish it was the gnome; I could simply feed it to my iguana. No wait, he's strictly a vegetarian I forgot!
83 1100 Ltd
- nob_1100
Is the bike equipped with a fuel gauge?
It is. It's working fine.
As for the sound when the tank cap is open, I'll have to check that later. Where's the cap vent? Is that the large rubber ring beneath the cap?
I just want to ask everyone this: do you feel pulsation when you touch your petcock (I have a mild fear that this sentence is taken to mean something else...)
83 1100 Ltd
- Thank you received: 2237
- nob_1100
It could be the petcock itself. If the spring is weak or if there is a small vacuum leak or if you don't hold your mouth just right, the petcock diaphragm can falp back and forth with the rhythm of the vacuum pulse from the carb. A plugged tank ventcould also contribute to the music.
Since two of your mentioned the possibility of clogged vent, can you please point me to the exact place where I should check? A replacement tank cap doesn't cost much, but I'd be happier if I can fix it.
I rebuilt the petcock last year (I think), and I assume the rebuild kit came with a new spring.
83 1100 Ltd
As to fuel gauge, was thinking maybe some part on sending unit was possibly bonking against inside of tank.
Good Luck!
- Locozuna
I'm betting on the gas level float.....
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- nob_1100
First, test by running with cap open or ajar, and if problem persists it's likely not vent related. If noise stops, then time to clear the vent.
Good Luck!
I just filled up the tank this morning, so I'll do the test when the level gets lower. Thanks for the explanation.
83 1100 Ltd
