no power at high rpm
- 82kz750e
- Thank you received: 2829
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2098
With strobe-type timing light, should be able to watch timing move back and forth as rpm is varied by blipping throttle.
Good Luck!
- telefunkin
Good Luck!
- JR
- Thank you received: 449
Like patton says check the compression and the advancer and valve clearances.
I have to admit I have never heard of slides not rising being a common problem with CV carbs with pods Perhaps take off the carbs and check the slides and particularly the rubber diaphragms looking for holes or rips.
Finally, and this may be a dumb question........but are you sure it's firing on all cylinders. Fire it up, let it warm for a minute and spit or spray water on the exhaust pipes. Should sizzle right off.
- nads.com
I tuned up a suzuki GS850 that would not go over 30mph without the box on.With 135 secondary main it should have lots of power. Assuming your carbs are Keihin CV34 like mine
- nads.com
