throttle questions
- Davestradamus
31 May 2009 10:45 #295300
by Davestradamus
throttle questions was created by Davestradamus
i have a 77 kz650b with a bit of a throttle issue. it doesnt recoil like it should, so i have to push the throttle closed by twisting it back.
questions:
one cable appears to be for opening, one for closing
right?
there seem to be tensioners on both, they are loose.
there is a spring on the rocker mechanism on the carbs where the cables attach. is this the only thing that automatically closes the throttle?
maybe the spring needs to be replaced? or some lube shot into the cable housings?
thanks!
david
questions:
right?
thanks!
david
- PLUMMEN
- Thank you received: 104
31 May 2009 11:00 #295301
by PLUMMEN
Replied by PLUMMEN on topic throttle questions
do the slides shut with cables disconnected? probably needs new cables,take throttle apart while cables are off and clean it up also
- Mark Wing
- Thank you received: 22
31 May 2009 11:30 #295304
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic throttle questions
It can also be the routing of the cables then self.
Mark
Mark
Yorba Linda Cal.
- Davestradamus
31 May 2009 14:50 #295325
by Davestradamus
Replied by Davestradamus on topic throttle questions
thanks everyone! i am going to take the cables off and lube them in the housings first, and make sure the throttle closes with no cable attached. if that doesnt fix it, where is the best place to get cables?
thanks,
david
thanks,
david
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
31 May 2009 15:06 #295330
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic throttle questions
I would say get you cables from Z1 enterprises, they are a grat place.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- bill_wilcox100
- Thank you received: 5
31 May 2009 15:55 - 31 May 2009 15:59 #295343
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic throttle questions
I had a similar problem on my '77 KZ650-B1.
I replaced the cable (lubrication may work well for you), greased the twist grip throttle assembly and greased the carburetor rail. The throttle effort and return became so smooth and light that I was able to replace the return spring on the carburetor assembly with one that has about 1/3 of the tension... this made it much more comfortable for and much easier on my vintage wrist for those longer trips.
Hope you can get away with just lubricating. Best of success.
Bill
Bill
Upgrades:
Montreal, Canada
Last edit: 31 May 2009 15:59 by bill_wilcox100.
