kz 1000 surging
- insanelane
27 May 2009 16:49 #294440
by insanelane
kz 1000 surging was created by insanelane
1908 kz 1000b4. Over the winter I installed emgo pods and a V&H 4into1 megaphone pipe. 125 main jets, 17.5 pilots. 28mm mikunis.I also had to tape up some of the pods and now I finally have all 4 plugs nice and tan. The problem is it has a bad surge out on the road at about 55 mph to 60 mph. Anyone else ever had this happen and been able to fix it? Any help very appreciated.
- PLUMMEN
- Thank you received: 104
27 May 2009 17:10 #294442
by PLUMMEN
Replied by PLUMMEN on topic kz 1000 surging
surge? does it seem to cut out in cross winds then come back to lfe suddenly?
- buckinrut25
27 May 2009 17:18 #294449
by buckinrut25
Replied by buckinrut25 on topic kz 1000 surging
I have had this problem with mikunis and emgo pods the best i can figure is that the rubber ring around the pods restricts air flow to the port that raises the needle valve i do not have this problem with k&n or universal foam the fact that you need to tape the pods means your still lean but i would only adress one issue at a time start with those pods if its an option put the air box back on and get the carbs set right for the pipes and then if you insist experiment with the pods
- insanelane
27 May 2009 17:24 #294451
by insanelane
Replied by insanelane on topic kz 1000 surging
yes it does seem to die out and come right back on.
- PLUMMEN
27 May 2009 17:26 #294454
by PLUMMEN
if it does it in cross winds that is the air being sucked or blown away from pod filters ,one of the advantages of stock airbox.
- keith1
- Thank you received: 2
27 May 2009 17:40 #294459
by keith1
Replied by keith1 on topic kz 1000 surging
for what its worth, i have had two sets of emgo s and had problems twice.....as expensive as k and n s are, you dont run into the problems with them that you do with emgos...last weekend i did two round trips over the newport bridge..water is still cold and temps drop 20 degrees up there and crosswinds have you struggle to stay in your lane...never one fart or hiccup with the k and n s .....just my .02......keith
- Sandy
- Fly High,Tony
- Thank you received: 13
27 May 2009 21:40 #294544
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic kz 1000 surging
I'm using the K and N pods,and don't have any issues.
However,when I was running the 26mm carbs,if I pushed my knees out away from the bike,into the wind,the bike would surge...since I put the 29's on...no problems at all.
1977 KZ1000 A-1
